Go to Post See, the boyfriend/girlfriend IS the robot. :D - sanddrag [more]
Unread 12-02-2008, 22:34
Tsom467 Tsom467 is offline
FRC #0467 (Shrewsbury Colonials)
Team Role: Leadership
Tsom467 will become famous soon enoughTsom467 will become famous soon enough
Team 467 Driving while holding the ball
The ball is fairly well locked in place too...
http://www.youtube.com/watch?v=a30z-o4CAqc
Unread 12-02-2008, 22:45
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Team Role: Teacher
Rookie Year: 1999
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: Team 467 Driving while holding the ball
That robot better be named 'Scorpion'.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 12-02-2008, 22:46
cloud_254's Avatar
cloud_254 cloud_254 is offline
AKA: Phillip King
FRC #1388 (Eagle Robotics)
Rookie Year: 2007
cloud_254 is on a distinguished road
i seriously agree it should be named scorpion
go big or go home
Unread 12-02-2008, 22:55
octothorpe's Avatar
octothorpe octothorpe is offline
AKA: Nick Felt
FRC #0766 (MA Bears)
octothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to behold
Cool design, I like the rounded-triangle base. How do you plan on outfitting it with bumpers?
Unread 12-02-2008, 23:06
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
Firstly...very nice design.
Secondly...just like when a fighter gets a ring fighting name....your robot should be called scorpion...because thats what the PEOPLE will call it
On to serious business...
I noticed that your robot has a point when you accelerate when the high COG (center of gravity) causes you to pop back. If you accelerate too quickly you might run the risk of falling over.
One way to combat this is to prevent very hard accelerations with you motors. You can do this by implementing a "ramping" algorithm into your motor code.
Basically, you program a shape to a ramp (either linear in the form of
motor speed = joystick_value *(x)
where x changes from zero percent to 100 percent over a set time period
You can also do sinusoidal ramps
motor speed = joystick_value * cos(theta)
where theta goes from 90 to 0. This will give you more of a ramping curve.
Hope this helps you some!
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 12-02-2008, 23:48
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
Rookie Year: 2007
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
You could also do a power ramp (e^x) or a quadratic (x^2) or a cubic (x^3). The posibilities are really endless...
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
Unread 13-02-2008, 00:47
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Ahh, but they all return roughly the same result The easiest way to implement an exponential curve, I believe, is by using the Taylor (or Mclaurin, in this case) expansion. In the case of e^x, the expansion is 1+x/!+(x^2)/2!+(x^3)/3!... I would not be surprised if calculators do this same thing to compute powers.
Unread 13-02-2008, 01:00
Re: Scorpion... LOL! That's what one of our team members said it looked like too! I have a feeling that is what it will be called.
Re: COG... while it did "pop" back a bit, it's actually quite stable.. there's plenty of weight in the bottom (the last weigh-in was 91 lbs), but there's still more to add, including the "skin", some more wiring, and we've already added more strength to the drive sections (all custom built, btw).
Re: ramping... we do have a ramping algorithm, that we've used successfully for the past couple of years, but I'll let our programmers comment on that. You can see last years (Rack & Roll) robot in the background too.
Unread 13-02-2008, 01:02
Here's another one:
http://www.youtube.com/watch?v=rtEbJ1zsqgc
These are all in low gear, by the way.
Unread 13-02-2008, 06:39
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Have you drive it on carpet yet?
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 13-02-2008, 21:27
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
looks good but a video of the max hight would be awesome .
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 13-02-2008, 22:43
I'll get one soon, but be assured that it reaches well above 6 1/2 feet
Unread 14-02-2008, 09:21
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
who is the guy with the cool beard?
how does he work the lathe??
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 15-02-2008, 00:13
Very carefully
  #15   Spotlight this post!
Unread 15-02-2008, 04:06
Caio's Avatar
Caio Caio is offline
Caio has a spectacular aura aboutCaio has a spectacular aura about
that is an amazingly slick looking robot...
i'll have to third, or fourth, the fact it should be called scorpion
Caio Tenca
Software Engineer
Founder of Washington SWAT Robotics
Ex-Team Manager, Mech. Leader of Westview Robotics Team 1510
Team 1510 co-founder
Former Team 955 member
Curie lives on in my heart <3
pic: FVC 3063 Holding Atlast Ball AdamHeard Extra Discussion 4 07-08-2007 22:48
Team 527 would like to thank team 467 and 358! ZZII 527 Thanks and/or Congrats 1 26-03-2004 00:05
pic: Holding the big ball CD47-Bot Robot Showcase 12 23-02-2004 22:14
Robot holding a ball... WIP ..image Salik Syed 3D Animation and Competition 7 03-01-2004 22:27
