Go to Post Thou shalt becometh pinned in eliminations. - JesseK [more]
Unread 13-02-2008, 10:24
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
Rookie Year: 2007
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
Radio Problems
Ok so we're having trouble programming the '08 robot. Our programmer blamed it on the electrical, so we took the I/O off the '07 bot and hooked it up on the '08 bot with the same code and used the same pwm ports, we didn't change anything. Then we hooked up the tether and everything worked as expected. The motors ran fine. So we know the problems we're having with the '08 controller is a programming error.
We then tried to hook up the radio to the '07 controller on the '08. Nothing happened. We're getting a no data/radio. What could be going wrong?
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
Unread 13-02-2008, 11:13
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: Radio Problems
Did you tether after you changed the team number in the 2008 controller so it sets it in the robot controller?
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 13-02-2008, 12:50
BenB's Avatar
AKA: Ben Bennett
Rookie Year: 2007
Re: Radio Problems
We haven't used the 2008 controller yet, we're still working on getting the 2007 controller working on the 2008 robot. The radio doesn't seem to be working.
Unread 13-02-2008, 14:09
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: Radio Problems
try to tether the robot then try to reestablish a radio link after you have tethered it.
Unread 13-02-2008, 16:06
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Rookie Year: 2007
Japper has a spectacular aura aboutJapper has a spectacular aura about
Re: Radio Problems
I apologize if this sounds stupid but....
Make sure that you have the correct modem connected to the OI and the correct modem connected to the RC...
They both look very much alike and will have the symptoms that you mention if they are swapped... I made this mistake once...
Radio Problems JimWright949 Control System 7 04-02-2008 20:46
Radio problems Charley Control System 11 15-02-2005 09:44
Radio Problems!! Please help arpus maximus Control System 23 21-05-2004 20:30
Radio Problems KWalsh Programming 3 24-02-2004 17:25
Radio problems -- not archiver 2000 1 23-06-2002 22:23
