Distrubtion Block to Fuse Panle/Block Wireing
Dose anyone know why on the E-Board you have to run one 6awg wire to each fuse panel/block? I have asked all my mentors and can't find any reason why this is need over running one wire to a Maxi block and distributing from there.
Re: Distrubtion Block to Fuse Panle/Block Wireing
Well, I would imagine that the MAXI block is on a higher breaker than the others. Not sure exactly though. Maybe just in good practice and to make everything separate?
The difference in the fuse would not be a problem, because the power from fuse block to fuse block does not go throught the fuse.
The main reason is that the rules say to do it the way the drawing shows.
One other reason is to keep voltage drops at one part of the electrical system from affecting other parts of the electrical system. |
| Modifying 40 Amp maxi fuse block | kborer22 | Electrical | 18 | 23-01-2007 10:12 |
| pic: Fuse Block | hockeystud91 | Extra Discussion | 0 | 21-01-2007 10:42 |
| [OCCRA]: Fuse Block | Frenchie | OCCRA Q&A | 1 | 21-10-2006 12:05 |
| Stinger Fuse Block and Power Distribution Block | Don Wright | Electrical | 2 | 30-03-2004 10:45 |
| pic: 40-Amp Fuse Block | CD47-Bot | Robot Showcase | 7 | 20-02-2004 00:23 |
