Go to Post "Recycle Rush? What's that, some sort of charity marathon?" - Chak [more]
Unread 13-02-2008, 15:05
Boydean's Avatar
Boydean Boydean is online now
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
Limit Switch Problem
Just to make note I don't really know if this goes in the Electrical or Programming...so move it please if its in the wrong one.
Ok, right now I'm having some problems to get the limit switch to work. We have it in "digital_io_18". the code is a simple.
Code:
if(digital_io_18 == 1)
 printf("Switch = %d",digital_io_18);
digital_io_19 = INPUT;
The problem is that its not changing states, but the controller LED "RC Hardware" is turning yellow(aka +5V output low) when its pressed
PS we have the switch on "normally closed"
PSS we are using kevin's 3.0 code
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
Using a limit switch thunderbolt Programming 1 02-04-2007 19:36
limit switch wedellm Electrical 4 16-02-2007 13:01
Limit switch in easy c? chadbarbe Programming 6 02-02-2006 09:51
