Go to Post Great people like you both [Scott and Libby Ritchie] make the FIRST community even better! - tiffany34990 [more]
Unread 13-02-2008, 15:59
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
Potentiometer problems
We have a strange issue with our pots.
Situation:
The potentiometers are wired properly, Power to pin 1, Signal to pin 2, Ground to pin 3, and connected to a PWM connector. We have tried this with 3 separate potentiometers, and they work properly when examined with a Digital Multimeter. However, when connected to the Robot Controller, a strange thing happens. The potentiometers start out giving the value off them as 70, however their output rapidly drops down to around 40, and then starts dropping slowly. The drop appears to be a logarithmic function. We've checked that it's wired to the proper port, plugged in the right way around, wired to the right pins.
Is there anything you can think of that would cause this kind of behavior?
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Potentiometer PID DustinB_3 Programming 28 15-02-2008 23:18
Potentiometer Problems Nicole_Ypes Electrical 7 08-02-2007 18:59
Potentiometer fezkazi Electrical 3 24-01-2007 13:29
Potentiometer Help! thoughtful Programming 4 18-02-2005 08:21
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
