Go to Post Its already begun folks...the Amanda you know is now one of us! mwahahahaha! - Andy Grady [more]
Unread 13-02-2008, 19:59
jumpe1990's Avatar
jumpe1990 jumpe1990 is offline
FRC #0647
jumpe1990 will become famous soon enough
Motor to Victor
Eh,....>_> Does anyone know if you can hook a motor's wires directly to a victor? As in without using anderson connector or a spade connector?
Unread 13-02-2008, 20:02
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
Team Role: Leadership
Rookie Year: 2007
seanl will become famous soon enoughseanl will become famous soon enough
Re: Motor to Victor
you can BUT its not safe which makes it not legal
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 13-02-2008, 20:07
jumpe1990's Avatar
FRC #0647
Re: Motor to Victor
....-confused-
Unread 13-02-2008, 20:16
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: Motor to Victor
You can hook up a motor to the victors terminals(M+, M-) with either ring terminals on the motor, or with two wires with spade and female connectors. However you do it, it has to be secure and safe.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
ShaneP's Avatar
ShaneP ShaneP is offline
Lead Mentor
FRC #0330 (The Beach Bots)
Team Role: Coach
ShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to behold
Re: Motor to Victor
Originally Posted by jumpe1990 View Post
....-confused-
Yes, it would functionally work, assuming you don't short anything with a stray strand of wire. Then you might have a bigger problem.
However, it's not recommended, and most likely won't pass inspection at the competitions.
Unread 13-02-2008, 20:18
seanl's Avatar
Rookie Year: 2007
Re: Motor to Victor
what exactly are you asking? if you can connect the motor without any connector crimped on?
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 13-02-2008, 20:28
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: Motor to Victor
What using just the bare wire leads you can but you will run the risk of one of the wires touching the other or worse the chassis and it's electrically not safe to do let alone you won't pass inspection by doing so. It's advised that you use a Ring or Spade connector that way it ensures that the only contact that those wires make are those of the victors power terminals. And it will also ensure a passing electrical system inspection b/c the judges WILL be looking for unsafe electrical connections esp. wires that are exposed.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 13-02-2008, 21:13
jumpe1990's Avatar
FRC #0647
Re: Motor to Victor
Er... no let say I have the 2 motor wire crimped with a ring connector and I attach that to the M+ and M- respectively. Is that legal?
I ask because our team normally does uses anderson connectors to connect a wire from the M+ or M- to one of the wires from the CIM motor.
Unread 13-02-2008, 21:15
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: Motor to Victor
Yes that is ok. And I thought the anderson connector refered to the hermaphrodite connector for the battery.
Kevin Li
596 - Sciclones
Unread 13-02-2008, 21:16
jumpe1990's Avatar
FRC #0647
Re: Motor to Victor
Do you know anyone rule number remotely close to prohibiting what I ask of?
Unread 13-02-2008, 21:17
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: Motor to Victor
Nope Ring Terminals are okay to attach directly to the motor wires.
Kevin Li
596 - Sciclones
Unread 20-02-2008, 09:34
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Motor to Victor
Jump,
This method is perfectly legal and in most cases recommended. Teams use the smaller Anderson plugs, when they think they may need to rapidly change out a defective component. By placing the Victor near the motor you are controlling, you can use larger wire to feed the Victor and reduce some of the losses of the motor wire and additional connectors.
Al
WB9UVJ
www.wildstang.org
________________________
Window Motor on a Victor? DavidGitz Kit & Additional Hardware 1 13-01-2007 09:42
motor stall current vs Victor ratings dawilliams Electrical 30 03-01-2007 08:29
Victor Input / Motor Control Jack Electrical 5 01-12-2004 02:23
Motor Question- Victor/Spike? 1166 Motors 10 16-02-2004 16:57
Window Motor With Spike/Victor supergrover Control System 9 30-01-2004 15:38
