Go to Post It's all about bragging rights, awards, and pushing the envelope, not necessarily winning or practicality. - ahecht [more]
Unread 13-02-2008, 20:07
bilal1219's Avatar
bilal1219 bilal1219 is offline
AKA: Bilal
FRC #1219 (Iron Eagles)
bilal1219 is an unknown quantity at this point
IR board.
Hi, I just wired my board recently.Here is the problem, When i hooked up the board it was working like the error led would light up and then turn off until i press the white button and the CMD 0 Lights up. The thing is when i hooked the Wire up on the 9v battery then i got is the error LED lighted up for 1 sec and then truns off and dosent light up again and even if i press the white button nothing happens. when i plugged the IR in the Fuse panel it still did the same thing. and when i took it out of the fuse panel,it did not work at all, even though i made sure that my wirings are correct. I checked wheather they are all getting voltage after i rewired it,I saw that only the wiring ribbon and the board is getting powered. The IR reciver is not getting powered.
I even read the post from before, Teams have said that its the regulator. But in this case does someone think its the regulator or not.Thank you for your help.
If someone has spare IR we would love to have it.
Bilal Shahid
Team 1219
<a href="http://www.thebluealliance.net/tbatv/team.php?team=1219" style="border: 0"><img src="http://www.thebluealliance.net/tbatv/teambadge/gen/1219/FF3300/0066FF/teambadge.png" alt="Team 1219" /></a>
Robots Might Lose But Teams Never Do
1458's board Andy L Electrical 5 26-01-2008 22:22
IR board joshuamorris Electrical 2 12-01-2008 19:43
IR Board? Pavan Dave Rules/Strategy 3 06-01-2008 19:10
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
