Dewalt Transmission Crisis!
Running 4 DeWalt transmissions on our robot, chain driven so that 2 of the transmissions are running 2 wheels. Unfortunately the victor's are setting the motors at 2 different speeds and tightening up one end, loostening up the other. When we run the 2 motors out of the same Victor, they are syncrod close enough that the wheels run, but when we stop it seems to lock up. Is there any way we can keep them being driven on through 1 chain, or should we split it and chain 1 wheel to 1 transmission/motor?
Re: Dewalt Transmission Crisis!
And... if it's easier/ quicker to explain on the phone, (603)831-0447 will get me.
Check to see if you have your brakes on the victor........not sure if this would cause the problem, but its a good idea to remove them for drivetrains.
I believe no jumper on the brake means no braking feature. |
Is this legal? and how do you do it? PM me
You take the Jumpers off of the Victors
It says nothing of the Jumpers in the rules...
There are actually two positions for the jumper; the leftmost two pins are for brake mode ("B") and the rightmost two are for coast mode ("C"). The jumper doesn't have to be removed entirely.
True. Although it has been determined that when removed it sets it to default; Coasting. As unnecessary as it was to remove them.... /shrug, I have no clue =P I'm tired, it's in the final hours of... lets be honest, it's in the beginning hours of completion...
Code:
<R62> All electrical loads (motors, actuators, compressors) must be controlled by relay or PWM output signals sent by the Robot Controller to an appropriate power regulating device Each CIM motor and Fisher-Price motors must be connected to one Victor speed controller. |
#10
Driving them both from one Victor was to test whether or not it was an electrical, programming, or mechanical problem, we ruled out some stuff via running them through one victor. We already decided that once we sync the Victors they are going to just keep getting out of sync, and unless we have some way to constantly sync them... which we have yet to find a way, then syncing them doesn't work. Unfortunately... we're in a time crunch
#11
We were, for the time running 2 victors off 1 PWM via y cable, but I read on another thread that it's more accurate to get them close to the same speed by calibrating it through running 1 victor per PWM
#12
we fixed it.... simple fix... backdrive pins were in.....
| Drawings/Model of DeWalt Transmission | sanddrag | Inventor | 30 | 23-12-2008 19:01 |
| DeWalt Transmission Problem | Kilroy0846 | Motors | 4 | 13-02-2008 09:24 |
| DeWalt Transmission questions | StevenB | Technical Discussion | 22 | 14-02-2007 16:02 |
| Dewalt transmission problems? | roach1051 | Technical Discussion | 10 | 11-04-2006 00:33 |
| DeWALT Transmission After Action Report | CyberWolf_22 | Technical Discussion | 7 | 17-04-2005 00:28 |
