Go to Post My experience in FIRST has taught me that, whatever you do, make sure that no single failure can eliminate half your drive system.[...] The worst feeling in the world is having your robot driving around in circles when there is critical business to be done on the playing field. - Andrew [more]
Unread 14-02-2008, 16:22
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
Question Help with Hybrid code
I have been having trouble with my Hybrid mode setup. I'm not sure what exactly is the problem, but I have been led to believe it is my sometimes flawed programming. (See my other posts if you don't believe me). I am using the provided IR board, and with a regular IR remote setup, for a VCR remote. The outputs are (supposedly) wired into Digital In/Out ports #1-4, and the IR board is receiving power.
Here is my code (it's a bit un-simplified, so propagators of KISS please don't complain too much)
Code:
/* Some globals: */
unsigned char offsensor1;
unsigned char offsensor2;
unsigned char offsensor3;
unsigned char offsensor4;
/* Initialize */
void Initialize(void)
   InitIRSensor();
/* InitIRSensor */
void InitIRSensor(void)
   offsensor1 = GetDigitalInput(1);
   offsensor2 = GetDigitalInput(2);
   offsensor3 = GetDigitalInput(3);
   offsensor4 = GetDigitalInput(4);
/* Autonomous */
void Autonomous(void)
   unsigned char irsensor1;
   unsigned char irsensor2;
   unsigned char irsensor3;
   unsigned char irsensor4;
   int action = 0;
   while( IsAutonomous() )
      irsensor1 = GetSensorInput(1);
      irsensor2 = GetSensorInput(2);
      irsensor3 = GetSensorInput(3);
      irsensor4 = GetSensorInput(4);
      if ((irsensor1 + irsensor2 + irsensor3 + irsensor4) >= 2)
         action = 0;
      else if (irsensor1)
         action = 1;
      else if (irsensor2)
         action = 2;
      else if (irsensor3)
         action = 3;
      else if (irsensor4)
         action = 4;
      else
         action = 0;
      HybridAction(action);
/* GetSensorInput */
unsigned char GetSensorInput(int sensorPort)
   unsigned char value;
   switch(sensorPort)
      case 1:
         value = offsignal1;
         break;
      case 2:
         value = offsignal2;
         break;
      case 3:
         value = offsignal3;
         break;
      case 4:
         value = offsignal4;
         break;
   return(GetDigitalInput(sensorPort) == value);
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
Help with VB code Setsanto Programming 8 08-02-2007 16:04
Help with code b-rant Programming 1 05-04-2006 13:52
Need help with code CaseyKasem_1251 Programming 3 18-02-2006 09:39
Help With Compressor Code fred Programming 6 21-01-2005 17:40
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
