Go to Post So basically, the advantage of #35 is that it allows you to be sloppier in your design and fabrication. If you pay close attention to these details, you will never have a problem with #25 chain. - Jim Zondag [more]
Unread 14-02-2008, 19:53
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
integer print not making any sense.
Hi, We are implementing a simple digital moving average filter of the output of the p1_y and p1_x. We are pretty much summing 8 numbers that should be in the range of 0-30 therefore should get an output of around 0-240...however this isn't the case for us. We are getting an output of something in the 7000s.
Thanks for your help!
Windell
Below is the code:
(at top of user_routines.c)
unsigned int yminus1,yminus2,yminus3,yminus4,yminus5,yminus6,ym inus7;
unsigned int tempy;
(outside of any of the functions in custom_routines.c)
extern unsigned int yminus1,yminus2,yminus3,yminus4,yminus5,yminus6,ym inus7;
extern unsigned int tempy;
/*implement a moving average filter to eliminate some of the noise of the p1 ADC*/
tempy=(int)p1_y+yminus1+yminus2+yminus3+yminus4+ym inus5+yminus6+yminus7;
yminus7=yminus6;
yminus6=yminus5;
yminus5=yminus4;
yminus4=yminus3;
yminus3=yminus2;
yminus2=yminus1;
yminus1=p1_y;
printf("tempy %d\r",tempy);
Unread 14-02-2008, 23:21
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
Re: integer print not making any sense.
To print unsigned integers, use %u instead of %d.
Very odd things can occur when printf uses the wrong specifier for the format, the least of which are unexpected values being printed.
--Eric
Unread 14-02-2008, 23:32
FRC #2477
Thanks esquared! That makes a lot of sense! I'm so used to only %f,%d,%s from writing C programs on Linux boxes that I didnt think of that.
HELP any tips for making promotional videos efoote868 Fundraising 3 19-07-2006 23:19
Ok, this does not make sense.... Michael Hill Math and Science 6 19-10-2005 17:42
integer division ImmortalAres Programming 5 11-07-2005 21:19
Kickoff is running again, @ 11:50 am - NOT ANY MORE!!! :( Elgin Clock General Forum 4 08-01-2005 22:30
Integer Number powercat Programming 2 18-02-2003 11:26
