Go to Post If I'm going to mentor someone, I'm going to be involved in their life as a positive force. - Mechvet [more]
Unread 14-02-2008, 20:20
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Occational weird value from Potentiometer
I have been testing out a Potentiometer on analog 2, and when I print back the data every once in a while I get a weird number, My terminal would look like such for example (this is at one set position, not changing much at all)
Code:
221
221
221
221
221
221
221
220
221
221
456
221
221
221
220
It works fine when I change the position, but it give me a weird number every once in a while which could mess things up. Has anyone else had problems like this or know why this is? Thank you
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Did anyone get a Value from the GTS? Da_Dude Programming 2 16-01-2008 15:17
Weird tangus value (i. e. tan(75)=27,XXX) DanDon Programming 4 16-02-2005 01:24
Weird Al? George A. Chit-Chat 6 13-07-2004 07:22
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
Weird Al MattK Chit-Chat 7 10-11-2002 00:33
