15 pin cabel and connector of OI
Where can I get one?
Thanks |
Re: 15 pin cabel and connector of OI
The easiest place is IFI.
Scroll down or search for DB15 If you're planning on making a competition port dongle or a custom switchboard for your OI, don't bother with that. There are better things to use. If you just need a cable, you can get it there. |
I think the quickest way is to buy a solder cup DB15 from radioshack and use a multiconductor wire like a cat5 cable.
hope this helps. |
I did not find any 15 pin connectors at Radio Shack...they have been obsolete for a while.
Sorry for the late reply....
I usually order most of our Teams "electronic" stuff from online mail order vendors. Mainly because our local RadioShack has done away with or stopped carrying the components we use. The DB-15 solder cup for example. I tend to use Jameco when possible and try to order in advance of the season for common items. DB-15 Solder Cup: http://www.jameco.com/webapp/wcs/sto...roductId=15035 Housing: http://www.jameco.com/webapp/wcs/sto...roductId=15019 Wire 15 Leads: http://www.jameco.com/webapp/wcs/sto...oductId=644455 |
go to l-com.com, they have everything in electronic
Radio Shack only sells the High-Density DE-15 connectors, which are used for VGA video for example. Standard DA-15 connectors are not carried by RS.
Aside from Jameco, also check DigiKey, Mouser and Circuit Specialists. Don |
Typically larger RadioShacks in smaller communities have more 'parts' and less consumer electronics. I don't know what your RadioShack is like, but most of ours around here are electronic toy sale centers, as opposed to part centers. It sounds like yours is more like the one by my summer home in Maine, in a very rural community. The guy there sells everything from connectors to albums, and high-end and low-end speaker systems that he bought in the 70s!
Jacob |
#11
![]() One of my saddest days was when they discontinued the Radio Shack catalog. I looked forward to it every year, and read every page as soon as it came out. I still have every year from the mid 70's to the end. (Maybe this post should go in the "I am a geek because ..." thread.) PS: If you want to see how to connect to the OI in style, see the Team 116 OI adapter board on my web site via my link below, and in the thread about it here. |
#12
We get a lot of small electronics parts from these guys:
Marlin P Jones |
#13
If you find an electronics store frequented by hobbyists
and repair people, you will find the connectors and cables that you seek. They are called d-sub connectors. You get the connector, the back shell, the crimp pins, and 15 conductor cable at the same store. You want the male connector and pins. Check your phone book for electronics stores and call them and ask if they have dsub connectors and tooling. We use the ss109 aircraft rated version, ordered from www.steinair.com. What you are likely to find at a local store is the commercial stamped pin version, but it will do just fine. Eugene |
#14
These connectors are called "DB-15", or "D-Sub 15" connectors.
Your local connector store should have them, as they are very common. Maybe even RadioShack. Worst comes to worst, you can cut off the connector from something else. You COULD order from digikey, but we ship in 3 days, so that would only give you about a day to build whatever you are trying to build. You can use just regular wire. (24,26 gauge.... Stranded telephone wire) Jacob |
#15
super easy, go here:
http://www.action-electronics.com/co...ight=db15#Db15 Order this part, a male to male 15 pin cable. S-15MM-10 It is less than $ 11 then cut it in half and then you will have TWO cables. and wire the end into your custom box and save the hassle of fabricating the OI end of the cable. |
| Anyone have any leads on the steering wheel controller that uses a 15 pin connector? | waialua359 | Control System | 20 | 30-01-2008 12:58 |
| what is the four pin white connector for on the ir board ? | Smaug | Electrical | 2 | 10-01-2008 23:37 |
| Quick release battery connector and 120 amps | n[ate]vw | Electrical | 6 | 18-01-2003 23:41 |
| DB15, Male 15 pin connector. | AdamT | Technical Discussion | 8 | 06-02-2002 17:17 |
| using set screw or dowel pin/pin to hold on drill motor coupler thinggy | Travis Covington | Motors | 1 | 04-02-2002 03:02 |
