Go to Post Check Chief Delphi, and if there isn't a post, make one. - sithmonkey13 [more]
Unread 15-02-2008, 09:23
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Uneven motors
After testing our drive train, I seem to have an issue with undistributed motors, how would I go about setting a particular voltage to each motor in easyc? We tryed using the gyro, but unfortunately, this tended to be too sensitive.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 15-02-2008, 13:36
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Re: Uneven motors
I highly recommend using the on-line window and recalibrating your Victors. We have found them to be way off the 127 center value. After calibration they were within +/- 1.
Using the gyro you can increase the deadband or you can reduce the output by dividing by a number.
gyro = GetGyro (1);
gyro_out = gyro / 2;
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Motors, Motors, and More Motors 1033missions Motors 1 09-02-2006 18:46
UnEven Floor??? sgsdragons Technical Discussion 18 23-01-2006 18:52
Motors.. and more motors.. How many on your 2004 bot? OneAngryDaisy Motors 33 23-02-2004 00:46
Uneven Thrust Loads on Needle Roller Bearings Madison Technical Discussion 7 07-02-2004 01:00
Matching Drill Motors and Fischer-Price Motors archiver 2001 5 24-06-2002 00:51
