Go to Post There are "Problems", and then there are "Solutions". Understand the Problem, and keep your mind open to alternative solutions. Don't get married to a Solution. - rich2202 [more]
Unread 15-02-2008, 15:53
aznbadboixx aznbadboixx is offline
FRC #1689
aznbadboixx is an unknown quantity at this point
Solenoid Help
We have a problem with our solenoid. We are using robotc to program it. The connection is piston to smc double solenoid to a spike. The pwm from the spike to relay 2. Everytime we I run this code. The spike light just turns red to orange everytime I press button 1 and button 2 or 3 interchangeably. The light never turn green. There is no moment in the smc solenoid. btw is the solenoid connects to two piston or only one. Is it our setup or our code. WE ARE DESPARATE WE NEED HELP. If somebody is around Bloomfield NJ and is willing to come in and help us. We will be forever grateful. We are meeting saturday and monday.
while(frcOIJoystickButtons[oiButtonPort2Button1] ==1) //
frcRelay[relay2] = relayFwd;
while(frcOIJoystickButtons[oiButtonPort2Button2] ==1) //
frcRelay[relay2] =relayRvs;
while(frcOIJoystickButtons[oiButtonPort2Button3] ==1) //
frcRelay[relay2] =relayOff ;
Solenoid Help Brigander Programming 2 14-02-2007 17:13
Help with the SMC SOlenoid FRC1710 Pneumatics 5 13-02-2007 13:22
Help with double solenoid almsfan21 Pneumatics 2 30-01-2007 19:57
solenoid valves? brian1717 Pneumatics 2 07-01-2007 15:28
Double Solenoid Help doyler Programming 4 19-02-2005 11:36
