Go to Post First and foremost, teach which end is the hot one on a soldering iron. - Al Skierkiewicz [more]
Unread 15-02-2008, 21:18
Spiders Spiders is offline
Rookie Team
FRC #2599 (Full Throttle)
Team Role: Leadership
Rookie Year: 2007
Spiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to all
Send a message via MSN to Spiders Send a message via Yahoo to Spiders
Flag Holder (?)
First of i wasnt sure where to post this lol. in this statement
"the FLAG is
approximately vertical and the top of the FLAG is 75 inches above the floor.
As the flag pole is approximately 36 inches long, that means the top of the
flag holder must be 51 inches above the floor."
it says the flag holder must be 51in. off the floor?? this isnt even possible for small robots, what do they mean? plz clarify, i dont get it, because the top of ours is about 35 in, must we have some long piece of metal sticking out the top connecting to the pvc in order to make it 51in.?
Unread 15-02-2008, 21:20
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Flag Holder (?)
"the FLAG is
You've got the solution there. Stick something long on top and attach the flag holder to that.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 24-02-2008, 07:02
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
Re: Flag Holder (?)
Team 1501 had a similar issue, our robot base in 27" wide and we needed to pass a 40" dia ball through the window over the robot which meant our flagpole would be hit be the ball. We initially thought to make it flexable and let the ball push it out of the way during the tossing of the ball. Then we got scared that the whipping action would loosen the flag and eventually knock it out. We devised a pivoting mount for the flag pole that swings the flag out 12" to the side of our base 500ms before we launch the ball and then retract it shortly afterwards to prevent it from be ripped off from a collision with another robot during our laps to retrieve the tossed balls.
Unread 24-02-2008, 07:25
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Flag Holder (?)
As long as it stays "approximately vertical", that sounds like a great solution.
1114 last year figured out a way to have their flag pole on their ramp, and then when the ramp deployed it would swing to remain "approximately vertical". Other teams who had the flag on the ramp allowed it to become "approximately horizontal" with nothing being said by the inspectors. Of course last year there wasn't a lap counter attached.
(since 2004)
Unread 24-02-2008, 10:26
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Flag Holder (?)
Curt,
Sounds like a good solution. I would like to see it.
Everyone,
Yes the rule does imply that a short robot needs to have some vertical structure to hold the flag holder at the required height. 51 inches +/- 1 inch above the floor per R17 and TU#5. Please remember only 1/2" Schedule 40 PVC with an end cap and no weight reducing holes. Please mark your vertical structures so that students in the pit will not hurt themselves leaning over the flag holder.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 24-02-2008, 13:09
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Flag Holder (?)
Originally Posted by Al Skierkiewicz View Post
Curt,
Look at their video...I'm not sure if the flag holder is on yet, though, in it. But it did show up in a picture in CD-Media.
Past teams:
Unread 24-02-2008, 13:10
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Re: Flag Holder (?)
Note that there's nothing really wrong with getting your flag knocked out, although if it happened constantly the judges might like you to fix it. You should be more worried about the lap counter-are you sure that there's going to be clear space around the top of it?
Unread 24-02-2008, 13:11
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Flag Holder (?)
I've seen pictures of the mount on the robot. They'll have clear space.
Past teams:
Unread 24-02-2008, 16:48
Re: Flag Holder (?)
Our main concern was in losing the lap counter. We also talked about it being a possible penalty if it was to happen every match especially if they were to be broken from being run over by us or other robots during the matches.
If you look at our video the flag holder was in the out position as the programmers hadn't installed the code to cycle it prior to the launching of the balls.
Flag, Flag Holder vs Trackballs Swampdude Rules/Strategy 29 09-03-2008 09:17
Flag Holder info Magnechu Kit & Additional Hardware 4 13-02-2008 19:08
Flag holder position Rosiebotboss General Forum 13 25-01-2008 22:11
Flag holder caps. General Thunder Rules/Strategy 10 28-03-2007 15:00
Drill Motor Holder Thunder360 Motors 4 21-01-2003 22:34
