Go to Post Listen to this FIRST: Thank you - Daniel Brim [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 15-02-2008, 22:34
eccmaster eccmaster is offline
FRC #2344
eccmaster is an unknown quantity at this point
What is the best way to power 3 chicklets
What is the best way to power 3 chicklets?
Unread 15-02-2008, 22:50
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: What is the best way to power 3 chicklets
The only way to power chicklets
<R106> Devices connected to the joystick ports of the Operator Interface via a FIRST-approved USB adapter (the only approved USB adapter is IFI Part Number USB-CHICKLET) are excluded from Rule <R105>. If used, this USB adapter must be powered with a 7.2V battery functionally identical to the back-up battery. Power from the competition port or any other source shall not be used to power the USB adapter. The USB adapter must be positioned within the OPERATOR CONSOLE so that the indicator lights may be seen during inspection and operation in a MATCH.
Unread 26-02-2008, 14:08
B.Johnston B.Johnston is offline
AKA: Bruce Johnston
B.Johnston will become famous soon enough
Last year we powered 2 chicklets using a Vex 2A/Hr battery and a y adapter.
We changed it only at the end of the day and it was barely drawn down while supporting a Logitech 3D Joystick and Gamepad simultaneously.
Unless your devices have some sort of active feedback you should see the same performance out of the Vex battery as well.
BTW we did plug and unplug the OI immediately before and after matches and practice sessions.
What would be the best way to go about getting a website? R Simpson Website Design/Showcase 13 30-01-2008 00:04
What do you think is the best way to pick up the ball? Jamin008 Technical Discussion 5 14-01-2008 20:47
Best Way to Shoot the Balls?? ben281 Rules/Strategy 54 16-01-2006 09:57
What is the best way for girls to get involved? lalala Chit-Chat 2 15-02-2005 18:31
What is the best way to learn? Tton 3D Animation and Competition 7 25-03-2003 19:22
