Go to Post It's rather simple: you start with a block of solid and remove material until you just have the robot left. Kind of like making a sandcastle. Only harder. - petek [more]
Unread 15-02-2008, 23:41
Hazmatt's Avatar
Hazmatt Hazmatt is offline
AKA: Matt
FRC #2645 (PowerSurge)
Hazmatt will become famous soon enoughHazmatt will become famous soon enough
Potentiometer arm control
Hello again. I've finally got pots mounted on my arm but I need a little help adapting them to my code. The arm has two pivot points, with a potentiometer mounted at each. The goal of my program is to make the motors move to keep the arm level until it's above the overpass at which point I'll press a button and have the ball get "flipped" over. I'm sort of stuck, and if someone could give me a hint on how to achieve this then that would be great.
Here's a picture of what's happening:
Mounting an arm potentiometer Hazmatt Technical Discussion 18 12-02-2008 21:53
P.I.D. Control for the arm skibum2490 Programming 8 27-02-2007 11:21
Slave Control Arm aaronD341 Control System 1 26-04-2005 17:13
2-Segment Arm Control Orborde Programming 1 20-01-2005 01:40
Neural Control of Robot Arm Leo M Math and Science 2 29-03-2004 13:46
