Go to Post If you want to prove your worth, prove it by creation, not destruction. - DanL [more]
Unread 16-02-2008, 12:42
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
Question Help with Wiring
Our team is mounting two seloniods on the claw. We need to run (roughly) 10 feet of wire to the claw. That means four grounds and four powered 24 gauge wires to run to the claw. We have some cat. 5E telephone wiring that has eight 24 gauge cables running through a sleeve. (With four different colors, and four white wires that we would use for grounds.) This woud work perfect for us but it might break rule R54
Use red, white, or brown wire for +12 Vdc and +5 Vdc connections.
Use black or blue wire for common (-) connections.
Can we use the wire??
The other four colors are:
Green
Orange
Brown
Blue
Thanks You.
Design. Build. Dew.
Need help with Wiring greendog99 Electrical 6 06-02-2008 17:01
Compresser Wiring Help Hastypickle Electrical 3 02-02-2008 19:16
HELP! We need pneumatic wiring help! BrittanyV Pneumatics 13 10-03-2006 09:26
need some help with the OI, and wiring a display pryoplasm Control System 8 10-03-2004 20:46
Good with Audio Wiring? Help me please. Rick Technical Discussion 10 04-11-2002 21:41
