Go to Post The dog-gear! Do u even shift bro? - WileyB-J [more]
Unread 16-02-2008, 15:47
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
Rookie Year: 2007
bronxbomber92 is an unknown quantity at this point
One joystick drive
Hi,
I'm trying to get something better than the default one joystick drive, but I don't really understand the concept of turning the x and y joystick values into values for each wheel motor (2 motors).
I'm planning on doing something along the lines of using a lookup table to make the robot more handlable, using thisa function instead of a look up table:
Code:
long ramping (unsigned char ramp)
    long answer = 0;
    answer =  ((long)ramp - 127);
    answer = ((answer) * (answer) * (answer));
    answer = ((answer) / (128 * 128));
    answer = (answer) + (127);
    return answer;
Can someone explain the concept for turning the joy stick values on each axis into something for each motor?
Thanks
edit - sorry for the typo in the name of the thread, I can't change it.
one wheel drive Simon Strauss Technical Discussion 11 16-11-2005 23:58
One Joystick Drive mattsavela Programming 20 19-05-2005 21:28
FIRST's one hour drive Duke 13370 Motors 4 25-02-2003 17:29
one stick drive Hendrix Programming 3 14-02-2003 20:53
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
