Go to Post Duct tape can fix everything except relationships with other people. - dixonij [more]
Unread 16-02-2008, 15:48
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
Thumbs up Programing IR board problem
Hey. We are trying to program autonimous with IR board.
here is our code:
Code:
 //**** Check the IR Sensor for a new command
  sensorReading  = PORTJ>>4;  // Combined digital inputs 15-18
  if (latch == 1)
    if (sensorReading == 0)
      latch = 0; // Take only the 1st reading to avoid being caught by a half & half state of the IR sensor
  else if (sensorReading != 0)
       latch = 1;
       if (sensorReading == 8)      IR_cmd = 1;
       else if (sensorReading == 4) IR_cmd = 4;
       else if (sensorReading == 2) IR_cmd = 2;
       else if (sensorReading == 1) IR_cmd = 3;
        printf("IR_cmd = %d\r\n", IR_cmd);
 switch(IR_cmd)
    case 0:
  		break;
    case 1:
		if (counter <= 50)
			pwm01 = pwm02 = 255;
			counter++;
		else
			counter = 0;
			pwm01 = pwm02 = 127;
	    break;
    case 2:
       pwm01 = 200;
       pwm02 = 55;
       break;
    case 3:
        pwm01 = 55;
        pwm02 = 200;
        break;
    case 4:
        relay1_fwd = 1;
This one loops forever. The problem is the counter = 0;.
If we remove it, the motors never stop moving
We want to have it configured so if button one is pressed, it will move forward for x seconds, and so on for the rest.
another problem is that the relay will not fire.
Any help will be appreciated. Thank you.
IR board problem AmitCarmeli Electrical 3 09-02-2008 18:53
Another IR Board Problem C222 Electrical 2 13-01-2008 17:36
Do you have a problem with the IR Board? DonRotolo Control System 5 07-01-2008 23:57
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
