Go to Post "Nuclear" is pronounced "nu kli Er." It is NOT pronounced "nu kU ler." When you use this pronunciation, no matter how smart you may actually be, you sound like an illiterate dolt (are you listening, Mr. Bush?). - dlavery [more]
Unread 16-02-2008, 17:16
koka230 koka230 is offline
AKA: Scooter
FRC #0388 (Maximum Oz)
koka230 is an unknown quantity at this point
Send a message via MSN to koka230
HELPPPPPPPPP!
Team 388 is using 2 - 3/4 in bore 8 in stroke actuators and one 24 in actuator as well. when using the 24 inch actuator, the pressure that is used to supply the side that make the actuator go up is completely fine. but is there any way to harness the pressure relieved from this actuator to put back in the pneumatics system?
thanks alot
scott
Unread 16-02-2008, 17:20
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: HELPPPPPPPPP!
Well, yes, but it might not help. See this thread.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 16-02-2008, 17:26
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: HELPPPPPPPPP!
One way to halve your air consumption is to not plug the top end of the cylinder, and then use either gravity or a spring to give you the return action.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
