Go to Post I can't wait to get to St. Louis!! Oh wait.. I'm already here!! - Team 288 [more]
Unread 17-02-2008, 07:50
hinewwiner hinewwiner is offline
hinewwiner is an unknown quantity at this point
Gyro ADXRS150 rate out
Hello.
I am having so much trouble with this Gyro.
I connected the gyro to the pic board(18F8722) and have the pic board sent the input from the gyro with unsigned int. and I am getting like 177~179ish in the hyper terminal from the serial port of the pic board.
Is this behavior normal? Also does anyone know how to use TEMP out of the gyro?
Thank you so much
ADXRS150 Gyro Yaw Sensor sensitivity? hinewwiner Technical Discussion 5 08-02-2008 09:20
ADXRS150 turn rate controller help required... dani Programming 6 23-05-2006 14:59
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 17-10-2004 02:28
ADXRS300EB Rate Gyro rmeenaks Electrical 18 05-04-2004 22:37
ADXRS300EB Rate Gyro rmeenaks Technical Discussion 0 31-03-2004 16:48
