#16
Re: Spike relay question
Also a COTS item from a robot previously entered in a FIRST competition may not be comercially available now. |
#17
There was a lot of confusion. The word from IFI is there is no difference between the red and blue 884. The blue 884 even had a case change a few years ago, but the internals did not change. The difference in the Spikes, as I remember, the Red Spike could pull both outputs to negative power but not both to positive. This required a few diodes to control dual solenoid valves. The Blue Spikes that are now provided can select both outputs to positive or negative power supply.
#18
That sounds about right Al, as i recall in 2003 being told we needed to use diodes with our double solenoid valves, and then discovering ourselves that we didn't. (2003 was our rookie year, and we were issued blue spikes)
| Spike Relay Wire Gauge | sparrowkc | Electrical | 7 | 12-02-2008 14:26 |
| Pneumatics (Spike Relay, Solenoid etc.) Programming | oceansidehs | Programming | 8 | 10-02-2007 13:58 |
| New Model Posted - 2005 Spike Relay | Ed Sparks | Inventor | 0 | 06-01-2006 20:41 |
| Spike (relay) module pin out | coreyjon | Electrical | 14 | 05-04-2004 07:05 |
| Spike Relay Input | nwagers | Electrical | 3 | 16-07-2002 22:23 |
