Go to Post Woo for speculation! - Eugenia Gabrielov [more]
Unread 17-02-2008, 16:51
Aratznes_Scythe's Avatar
Aratznes_Scythe Aratznes_Scythe is offline
Project Leader
FRC #1293 (D5 Robotics)
Team Role: Mechanical
Aratznes_Scythe is an unknown quantity at this point
Mounting the IR board
How have you all been mounting your IR boards on the robot? We are unsure of how/where to mount ours and would like some advice. Thanks so much!!
Unread 17-02-2008, 16:52
Danny McC's Avatar
Danny McC Danny McC is offline
Taking one home in '09.
AKA: Danny McCanney
FRC #0816 (The WesTech Anomaly)
Danny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant future
Send a message via AIM to Danny McC Send a message via MSN to Danny McC
Re: Mounting the IR board
You can pretty much mount it anywhere. Just make sure that it can get the signal from the remote.
Unread 17-02-2008, 17:19
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
Team Role: Leadership
Rookie Year: 2007
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
we put the back on some plexuglass, then zip-tied i to our tower
Unread 18-02-2008, 01:23
Barak Shelef's Avatar
Barak Shelef Barak Shelef is offline
FRC #3316 (D-Bug)
Rookie Year: 2007
Barak Shelef will become famous soon enoughBarak Shelef will become famous soon enough
we mounted it on some insulating foam and bolted it to the robot and added some protections around it.
Unread 18-02-2008, 02:07
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
we mounted it safely on the electronics board within our robot the soldered on some extension cables and put the sensor at the highest point of our bot... it seems to work very well
Pneumatics Board/Mounting Components ASmith1675 Pneumatics 2 06-02-2008 13:47
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
mounting of the small gear directly to the shaft of the drill Andrew Dahl Motors 0 19-01-2004 12:18
Mounting weights on the side of the bridge? archiver 2001 4 23-06-2002 23:01
Mounting weights on the side of the bridge? archiver 2001 0 23-06-2002 23:00
