Go to Post All the powerhouse teams will be having powerhouses dinners with each other in the powerhouse restaurants, probably. - T^2 [more]
Unread 17-02-2008, 19:13
Torboticsmember's Avatar
Torboticsmember Torboticsmember is offline
AKA: Alan Bartow
FRC #2080 (Torbotics)
Team Role: Driver
Rookie Year: 2007
Torboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to all
Near Vertical Flag Holder
Our team is wanting to put a flag holder on our mast, which can change angle about 20 degrees or so. At start the mast will be 20 degrees from vertical. So our question is what is near vertical. And also does all possible playing configurations include starting configuration, this is because at the beginning of the match our mast goes to 90 degrees, if it does not change after this will that be ok.
We lost our Q&A name so we can't ask a question to the GDC
Unread 17-02-2008, 19:23
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Near Vertical Flag Holder
Closest Q&A that I can find: http://forums.usfirst.org/showthread.php?t=8285
So the answer to your second question is, it would probably be legal. As to your first question, I don't know. I would, however, say that 20 degrees is probably a little far.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 17-02-2008, 20:37
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Although it is doubtful now that you would get a question answered before Ship, you can have your mentor request a new password. I forget if it is in TIMS or in the Q&A login.
(since 2004)
Unread 17-02-2008, 22:25
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
Team Role: Leadership
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
I believe the purpose of "approximately vertical" is simply a better way of saying "close enough that its hard to say it is or not. The inspectors do not want to use a level or other device, but 20 degrees off vertical is definately too much. And yes, your starting configuration is considered a playing configuration (you have to start the match in the starting configuration).
Unread 21-02-2008, 07:35
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2000
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
As an inspector I would not allow 20 degrees to be NEAR vertical.
Maybe 1-3 degrees would look alright.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 25-02-2008, 20:42
Jaybee1405
Posts: n/a
TIMS has your teams username and password on the right hand side in bold letters.
Flag, Flag Holder vs Trackballs Swampdude Rules/Strategy 29 09-03-2008 09:17
Flag Holder (?) Spiders Technical Discussion 8 24-02-2008 16:48
Flag Holder Mounts RoboGeek99 General Forum 10 17-02-2008 19:32
Flag holder position Rosiebotboss General Forum 13 25-01-2008 22:11
Flag holder caps. General Thunder Rules/Strategy 10 28-03-2007 15:00
