Go to Post This is a game folks, and rules are rules, even if you kinda sorta broke one rule in the end its still broken - Mike Schroeder [more]
Unread 17-02-2008, 21:33
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
Pressure Sensor
I was wondering if there is any pressure sensors we can get for the robot. Not the pressure switch that's used for the compressor (we have one of those wired up and it works great), I mean a sensor that can tell the robot the exact pressure in the system (so I can pass it to the OI).
Has anyone done this, and if yes, where did you get your sensor?
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Unread 17-02-2008, 21:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Pressure Sensor
We bought a Nason pressure switch from McMaster-Carr, they sell them for preset pressures in 5 psi increments. we got an 80 psi switch, it turns on a light on the OI and tells the drivers that there's enough air to shoot the ball reliably.
They also sell pressure transducers and you can get them from other places like DigiKey, but this seems to be all we really needed, and it was easy to implement.
Unread 17-02-2008, 22:33
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Pressure Sensor
You can get a pressure sensor that reads in voltage; for example look at Fluke (the multimeter folks), they sell a sensor kit like that. It is surely overkill for your application, but it shows that there are pressure sensors out there.
Don
Unread 18-02-2008, 02:02
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: Pressure Sensor
Based on your team number, I'm guessing you're a rookie team this year. If you can find a team thats been around since 2004 in your area, the 2004 KOP had a pressure transducer in it, that functioned as a simple analog sensor, and there was a relatively easy conversion factor to have it read out psi on that user variable on the OI.
pressure sensor drosophyllum Pneumatics 6 05-12-2007 20:49
TI Pressure Sensor this year? kmcclary Pneumatics 1 20-01-2005 20:53
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
Pressure Sensor Readings ErichKeane Pneumatics 17 28-01-2004 09:58
Pneumatic pressure sensor Curtis Williams Pneumatics 3 04-02-2002 20:09
