Go to Post I don't think that FIRST is going to get better with a top down solution alone, it is going to take a grass roots effort to strengthen teams. That starts by teams getting off their "islands", self imposed or otherwise. - Fe_Will [more]
Unread 17-02-2008, 21:44
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Baffled by Encoder
We are using encoders on our transmissions. We are using Kevin Watson's Encoder library (from last year, not new).
In our experiments (due to things not working) we can move the encoder connections from 1-11 to 2-12, etc. Only 1,2,3 work, 4,5, & 6 do not.
This completley baffling to me. I've poked in some printfs in the interrupt handlers with enough information before crashing that the correct handler is getting called but not recording (I think down) transitions. That is the count is never incremented.
I'm not sure what's hapenning or why the same encoder that works on port 3 does not work on 4, 5, or 6.
Any ideas would be most helpful.
Thanks,
...Duane
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
encoder wiring karin l. Motors 3 07-02-2007 00:14
Encoder Error Anime-niac_2.9 Programming 1 27-01-2007 16:23
Encoder Hookup kutty18 Electrical 4 22-01-2005 12:17
encoder.c Gary Bonner Programming 2 14-01-2005 13:41
encoder vs. motor stephenthe1 Programming 55 06-01-2005 22:07
