picture/diagram of controllable single/double
does anyone have picture or diagram of the controllable actuator system, using a single to control air to the double?
i have tried following the text instructions i have searched however none seem it do it. |
Re: picture/diagram of controllable single/double
Sorry to bring this back up but does any one out there have this digram or a link to it
Thanks |
It looks basically like this
Code:
-------- EA ---------- EA
| |------\ P | |-------| (plug)
Pressure In-----| DS | EB |--------| SS | EB
| |------/ | |-----> (open to atmosphere)
| | A| B|
A| B | \__/
An alternative is to just buy the correct solenoid valve to allow for mid-cycle positions called a "Three-position pressure center" valve. The spec sheet is here. Look at valve type SY3520-6H, for example.
Don |
That works too, under the current rules. The system I laid out above, and personally devised in ~2004 (maybe not the first to do so, but I did it on my own) works with exclusively KOP parts, and I would argue can be made better (with addition of a couple other components) than a center off valve, as far as stability/accuracy goes.
| wiring diagram | Smaug | Electrical | 7 | 01-10-2007 21:39 |
| Single vs double solenoid valve operation | Scott358 | Pneumatics | 0 | 29-01-2005 11:47 |
| Need instructions for SMC Single/Double solenoid | WHou | Pneumatics | 5 | 29-01-2005 08:17 |
| using single solenoid like a double | SteveO | Programming | 14 | 02-02-2004 22:51 |
| Diagram of shelf | Joe Johnson | Off-Season Events | 0 | 13-10-2001 08:45 |
