Go to Post That's not duct tape as adhesive, it's duct tape as decoration! :p - Don Knight [more]
Unread 18-02-2008, 04:39
ericsundbergva ericsundbergva is offline
FRC #1541
ericsundbergva is an unknown quantity at this point
Question Wiring 2 CIM motors to one Victor
I am a mentor for 2 teams. Two CIM motors per wheel with one Victor appears to be disallowed, see below. Can you use two Victors (one per motor) with a common PWM input to get around? The motors would have tied output shafts via the transmission. Is the Inspection Item 300 Rev E the final word?
RULES: REV E, FEB 5, Inspector List ITEM 300
"Motors can only be driven by one Victor or Spike with only one motor per permitted per Victor/Spike"
This complies with rule R-62 I think,
but the old inspection Rev D, JaN 25, did ALLOW IT:
Motors can only be driven by one Victor (although a Victor can drive more than 1 motor).
Thanks!
Unread 18-02-2008, 05:30
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: Wiring 2 CIM motors to one Victor
Each CIM must be connected to exactly one Victor, and that Victor may have no other load connected to it. You are permitted to use a PWM Y-cable to control multiple Victors from the same pwm output on the robot controller.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 18-02-2008, 10:12
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
We do this as well ... one motor per Victor. A "Y" PWM cable (the black-red-yellow one of which 2 are supplied in KOP) goes from ONE PWM output on the Robot Controller to both Victors.
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Cim motors trhgammer Motors 1 15-02-2006 12:31
CIM Motors UlTiMaTeP Motors 13 10-01-2006 14:48
6 CIM Motors? psquared89 Kit & Additional Hardware 16 09-01-2006 08:47
CIM Motors rocky ali Motors 2 24-09-2005 17:55
