Go to Post We may not have any Paris Hiltons around here (though I've heard Paul Copioli is a great kisser) - AndyB [more]
Unread 18-02-2008, 08:24
jonboy jonboy is offline
Engineer/Mentor
FRC #0885 (The Green Team)
jonboy is an unknown quantity at this point
EasyCPro function variable return?
How does a user defined function in EasyCPro return more than one variable? What I found works is to declare the variables as global variables. Is this the only way to do it? I don’t necessarily want to get into pointers at this late date.
... jon
Unread 18-02-2008, 09:12
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Re: EasyCPro function variable return?
1.) Create a new function:
2.) "Return Type" should be set to the variable type your function is returning. If your user function does not return a value, leave this field void
3.) Drag a "Return" block inside your function and select the variable name.
A function can only "return" 1 variable.
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 18-02-2008, 10:02
Engineer/Mentor
TNX
Hope to see you at BAE Regional!
... jon
Unread 18-02-2008, 11:22
Kingofl337's Avatar
AKA: Adam
Rookie Year: 1998
You too, good luck!
Drive Function in EasyCPro, anyone? JustineSHA Programming 3 08-02-2008 20:41
Upgrading EasyCPro 3.1.0.7 to 3.1.0.8 Mike Smith Programming 2 12-01-2008 15:24
Upgrading to easyCPRO koenig3456 Programming 5 17-01-2007 09:08
