Go to Post The thought of destroying any robot is just......depressing :( - Richard McClellan [more]
Unread 18-02-2008, 10:44
Sykan's Avatar
Sykan Sykan is offline
Lead Programmer
AKA: David
FRC #0540 (Team 540)
Sykan is on a distinguished road
Interrupt Trouble
i've been testing my encoders and encoder 1 doesn't count intill the other encoder has something to count
i donno but it doesn't seem that interrupt 1 is called intill interrupt 2 is called and vis versa.
any ideas?
Thank you, in Advanced
Unread 18-02-2008, 11:04
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Interrupt Trouble
Are you using MPLAB or EasyC? Are you using Kevin Watson's encoder code? Can you post your interrupt handler code? We need some more information before we can make intelligent suggestions. Offhand, I can suggest that your interrupt handler isn't correct in some fashion, you've forgotten to enable interrupts on the encoder pin, you've plugged the encoder into the wrong place, your encoder simply isn't working properly or isn't sending strong enough signals.... Unless you want to spend the day running down every single random idea we can toss out, please post more info about what's connected where physically, and what your program actually is.
Unread 18-02-2008, 11:53
Sykan's Avatar
Lead Programmer
AKA: David
The Encoders are connected to Port 1 and 2 of digital input.
i'm Using Kevins Code with Mplab
Sense i'm using the KOP Encoder i've changed the Interrupt handler to
if (pwm16 >= 127){
Encoder_1_Count += ENCODER_1_TICK_DELTA;
else {
Encoder_1_Count -= ENCODER_1_TICK_DELTA;
for both oh/course with the correct corresponding Motor and Encoder Count.
i've Enabled the Int in the ifi_frc.h, the Encoder.h and the Initialize_Encoder_1(); in the teleop.c
I haven't Changed anything else
Unread 18-02-2008, 13:02
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
any ideas?
I'll look at your code if you zip it up and send it to me.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 18-02-2008, 15:51
FRC #2429
any ideas?
Having had a quick look at your code, nothing jumps out. What exactly is malfunctioning?
-Kevin
Kevin Watson
http://kevin.org
Unread 18-02-2008, 16:07
Rookie Year: 1998
I'm kind of curious if he's updating pwm16 atomically so it's guaranteed to be in a valid state in the ISR. If he's left the default routine in and then updates it later in the routine he could get some odd effects every 26.2ms or so.... Also, there' always doing a clean build in case something's gone haywire.
Unread 18-02-2008, 16:44
tern540degrees's Avatar
tern540degrees tern540degrees is offline
AKA: Ben
FRC #0540 (Talon)
Team Role: Leadership
tern540degrees is an unknown quantity at this point
We figured it out. The signal was grounded through the frame. Thanks for all of the help.
"...each man calls barbarism whatever is not his own practice..." That makes us all barbarians.
interrupt enable 3dude_2231 Programming 6 10-02-2008 16:08
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
Interrupt question Kashi Chan Programming 2 07-03-2005 08:28
enable interrupt Dean Programming 2 13-02-2005 07:37
Interrupt limitations? randomperson Programming 2 27-12-2003 21:40
