Greetings!
We are trying to get the servos in our transmission working. Outputting on pwm12 to the servo does absolutely nothing to the servo. Is there something extra needed in the code to make the servos respond? An external power supply? Thanks! |
Re: Anything special needed for servo programming?
The backup battery supplies the power
But wouldn't the big ol SLA battery supply power even if there is no backup battery? The speed controllers work fine. If I were to plug the servo PWM into the normal port for a speed controller, shouldn't it work fine? Because it doesn't. :-[
In '05, 330 had a wedge on the back that was servo-dropped. That wedge didn't work if there wasn't a backup battery. Plug the backup battery in. I think you'll find it works. |
Everything is peachy.
Thanks guys! |
| Servo Programming Again..... | programmr | Programming | 1 | 14-02-2008 09:31 |
| Help needed in autonomous programming for hybrid mode | Team_STORM | Programming | 3 | 21-01-2008 19:11 |
| pic: Notice anything special? | Beth Sweet | Extra Discussion | 9 | 20-06-2006 10:53 |
| Servo behavior question / advanced servo/PIC programming question | DanL | Electrical | 12 | 18-10-2005 18:33 |
| What do you plan on brining to your competetions,anything special? | SwordSerenity | Chit-Chat | 23 | 12-02-2003 20:26 |
