Go to Post We all know that with mechanical systems, once all the noise has leaked out, the system quits (therefore quiet running mechanical systems last much longer :^) - KenWittlief [more]
Unread 18-02-2008, 14:34
b1zkit b1zkit is offline
FRC #2345
b1zkit is an unknown quantity at this point
PWM Speed
This is our first year and we are having some problems with the programming. We need to set a lower maximum value for the PWM02 motor. Something like 200. We are using the default code. How would this be achieved?
Unread 18-02-2008, 15:14
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
Rookie Year: 2007
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: PWM Speed
You would probably want to scale the precision of whatever control mechanism or joystick you are using to get the full scale of motion, so this should graph that to the new maximum:
Code:
long answer; //Must be long to hold precise values
if (p1_x > 127){ //Or whatever joystick
answer = p1_x * 200 / 255;
pwm02 = (unsigned char)answer; //Cast this to the proper type
} else {
pwm02 = p1_x;
Unread 18-02-2008, 17:09
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
Rookie Year: 2007
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: PWM Speed
Code:
} else {
pwm02 = p1_x;
While the above code would work, you don't need to use a long variable, which I'm assuming you're using to prevent overflow. Another approach would be to just cast the result:
Code:
#define MAX_VALUE 200 //Replace 200 with whatever you want your max value to be
Put the #define at the top of your file. On compile, the compiler will insert 200 (or whatever you decide you want your value to be) wherever you write MAX_VALUE. This way, if you want to change what the max value is later, you can simply change it at the top of the file instead of fishing through your code. This is especially useful if you use it more than once.
Then, the actual solution:
Code:
if(p1_x > 127) //Replace p1_x with whatever joystick and axis you want
     pwm02 = (unsigned char)((long)p1_x * MAX_VALUE / 255);
else
     pwm02 = p1_x;
This code first casts the expression as a long so that overflow doesn't occur, then casts it back to an unsigned char so it can be assigned to pwm02. No variables are used.
Digital out signal speed on off, almost like PWM but at max 60Hz Generalx5 Electrical 2 27-03-2007 12:26
trouble with pwm speed controller jakk Control System 4 10-01-2005 02:51
trouble with pwm speed controller jakk Electrical 4 10-01-2005 02:51
Ugh...PWM pin vs. Speed Controller archiver 2001 1 24-06-2002 00:27
Speed Controller/PWM problems.... Clark Gilbert Technical Discussion 8 08-01-2002 00:14
