Go to Post just thinking about the array of mechanisms awaiting my examination tingles the thinky parts of my brain. - Tytus Gerrish [more]
Unread 18-02-2008, 14:52
Ian G Ian G is offline
BUILD SUCCEEDED
FRC #2415 (WiredCats)
Ian G is an unknown quantity at this point
Send a message via AIM to Ian G
Basic Stamp serial communication
We are trying to use a BASIC Stamp 2 px (BS2px) to preprocess Sonar data. I am not very familiar with stamps, but it is what we had on hand and interfaces well with the sonar units. So, making the Stamp and the RC talk to each other is stumping us. Using a TTL to serial adapter, we were able to make the RC send data to the stamp, but were unable to read a response. It is wired correctly, both are at the same Baud, and the code (which I do not have on hand at this moment to post, but will be happy to retrieve when I can) seems correct, at least on the C side of things.
I read somewhere that the BS2px relies on the device it is communicating with to provide the normally high voltage on the serial communication pin. Does the TTL board satisfy this? If not, would using a BS2 project board with a serial port, and connect it to the program port on the RC work? Thanks for any help. I am sorry if this post was hard to follow, you know how the day before ship is.
Serial Communication to a Cmucam3 Lawrey Programming 0 03-09-2007 21:38
RS232 (Serial) Communication To OI bglass Programming 9 07-07-2007 04:04
Serial Communication in C++ Adam Shapiro Programming 8 21-01-2003 12:49
no basic stamp found! DLyons Programming 7 23-12-2002 22:17
serial communication using c++ Malakili Programming 31 01-05-2002 15:51
