Go to Post Unfortunately, there's no special type of transmission that will magically get you past defense. The best way to deal with defense is to practice, regardless of gearing. - connor.worley [more]
Unread 02-18-2008, 08:31 PM
Trav-O's Avatar
Trav-O Trav-O is offline
THE PROGRAMINATOR
AKA: Travis
FRC #0510 (Hawaii 5-1-0)
Team Role: Tactician
Trav-O is infamous around these partsTrav-O is infamous around these parts
digital inputs: some bad?
ok, so I heard a rumor a long time ago that the higher number rc digital inputs have questionable functionality... is this true?
the reason this concerns me is that i'm trying to get signals from my IR board... The board does give signals when you press the corresponding buttons on the remote controller (i've checked with a multimeter) BUT the code doesn't seem to want to register the signals... (btw, there are no code errors. I'VE CHECKED! trust me on this) when we replugged the pwms into digita inputs 1 2 and 3, the switch 1 2 and 3 leds came on, binking when we pressed the remote controller buttons so yea...
Be safe!!! OR YOU MIGHT GET INJURIES!
Set Default Digital inputs to Low? How? bad Analog value? Generalx5 Programming 11 01-04-2007 06:57 PM
Digital inputs in autonomous mode? Calvin Programming 8 02-18-2006 01:16 PM
How to access other Digital inputs on OI? DougHogg Electrical 2 03-12-2003 01:57 PM
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 01-20-2003 04:08 PM
Analog vs Digital inputs? f22flyboy Programming 8 11-08-2002 10:18 PM
