Go to Post What happens when everything becomes fully swagged out? Also, does my robot need to have collar-popping functionality to use every feature? - AlecMataloni [more]
Unread 18-02-2008, 23:03
Guarana Guarana is offline
FRC #1706
Guarana is an unknown quantity at this point
gyro problem
I have the gyro on the analog input 01. i am using kevin's code with the gyro and adc enabled. i am getting a reading in the printf for both the rate and the angle. coding it is the trouble.
i am using mecanum programming i found from alan. it works very well on its own.
Code:
function:	deadband()
inputs:	inp, input value
		center, value of input that represents neutral
		band, size of deadband to consider neutral
output:	scaled and deadband-compensated output value
		inputs below center will yield negative output
		inputs above center will yield positive output
		inputs within deadband either side of center will yield 0
usage:	typically call with joystick value (0-254) as input,
		joystick neutral (127) as center, and a small number (5)
		as the size of the deadband.  The white POS joysticks
		should probably have a much larger band (10) instead.
int deadband(int inp, int center, int band)
int oup;
	if (inp < center-band)
		oup = inp - center + band;
	if (center-band <= inp && inp <= center+band)
		oup = 0;
	if (center+band < inp)
		oup = inp - center - band;
	return oup;
function:	pwm_limit()
output:	scaled and range-limited output value
usage:	call with signed value (+/- 127) as input,
		will return a valid pwm value
unsigned char pwm_limit (signed int inp)
	if(inp<-127)
		inp = -127;
	if (inp>127)
		inp = 127;
	inp = inp+127;
	return (char)inp;
void Teleop(void)
	l_y = deadband(p1_y,127,10);
	r_y = deadband(p2_y,127,10);
	l_x = deadband(p1_x,127,10);
	r_x = deadband(p2_x,127,10);
	l_y = l_y/2;
	r_y = r_y/2;
	l_x = l_x/2;
	r_x = r_x/2;
	speed = l_y+r_y;
	turn = l_y-r_y;
	slide = -l_x-r_x;
	if(temp_gyro_angle <= -75) //gyro
		turn = turn+15;
	if(temp_gyro_angle >= 75)
		turn = turn-15;
  	front_r = speed-turn+slide;
	front_l = speed+turn-slide;
	back_r = speed-turn-slide;
	back_l = speed+turn+slide;
	pwm01 = pwm_limit(front_r);
	pwm02 = 255 - pwm_limit(front_l);
	pwm03 = pwm_limit(back_r);
	pwm04 = 255 - pwm_limit(back_l);
The commented out part is mine. It is simple and looks like it should work, but whenever the gyro is plugged in, the victors 'flicker'. the orange lights flash very quick, and the wheels get a quick power burst to it, over and over. when the gyro is unplugged, its fine.
suggestions?
Problem with gyro... capenga Programming 21 16-02-2006 19:25
Gyro not accurate - Problem naor52 Programming 15 27-01-2006 16:50
Gyro code problem AMIRAM Programming 10 23-01-2006 04:26
Gyro magical hands Programming 2 14-01-2005 20:57
