Thread Tools |
Rating:
Display Modes |
Team 1896 had a rough start when it came to the IR board, but we finally figured it out. So, we decided to be nice and share our findings.
Here is how we did it: The IR board itself is powerd from a standard DC 9-volt battery on pins 1 and 3. 2 and 4 are unused but you COULD use them to further secure your connections. Pins 1 and 2 are for positive battery input, while 3 and 4 are for negative battery input. Then we ran the white(signal) cables from 4 PWM wires to pins 5-8 on the IR board, These carry the actual signal from the board. The 4 leftover black and red cables of the PWMs that are connected to the Ir signal pins were ran together with there respective color. All 4 red wires ran to one single RED wire, and all 4 black wires ran to one single BLACK wire... These RED and BLACK wires were then ran to the black and red wires of another PWM and that PWM was ran to a PWM output on the IFI board. This output can then be set to 255 to make the IR board signal pins act as normally open switchs that are connected to digital inputs. If you have any questions please feel free to ask. ~Justin from team 1896 Motivating quote of the day: A civilization is built on what is required of men, not on that which is provided for them. -Saint-Exupery, Antoine De |
| Getting constant motor power with IR board | Nightfall831 | Programming | 16 | 15-01-2008 11:20 |
| Getting the camera to work in autonomous | dpick1055 | Programming | 8 | 10-02-2007 20:57 |
| Getting the Camera and Default Code to Work | nukem | Programming | 5 | 18-01-2006 11:48 |
| Does anyone on this board work at home depot? | mnkysp6353 | General Forum | 2 | 30-12-2001 13:27 |
