You make my motors hot!
  #16   Spotlight this post!
Unread 22-02-2008, 13:59
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Compressor blowing spike fuses or melting spikes
Originally Posted by de_ View Post
Out of spec excessively tight clearance between the compressor piston and cylinder wall could increase current draw but since nobody else has seen this and since the compressor seems to be starting and running fine, that doesn't look likely.
This compressor uses a "wobble" technology in that the piston and rod are one piece so that the piston head actually wobbles as it is moved by the crank. The seal is flexible and so the piston to wall clearance is fairly big (i.e. on the order of hundredths as opposed to thousandths of an inch.)
A 30 amp fuse violates the wiring rule and IFI requirements for the Spike, sorry.
Al
WB9UVJ
www.wildstang.org
________________________
  #17   Spotlight this post!
Unread 23-03-2008, 13:16
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Just to let you know, we changed to the circuit breaker and (probably) did not have any more problems with the compressor. However (in spite of continous maintenance efforts) we suffered from an increasingly severe lack of air pressure, most likely due to a leak in a internal seal in (one or more) SMC solendoids.
We have not way to prove if the circuit breaker ever tripped during the matches but so far we cannot find any evidence of it. The one spike whose case melted around a terminal and the terminal was found to be no longer soldered to the printed circuit board was likely a poor (high resistance) soldering job in manufacturing as nothing else seems to explain it.
Compressor fuse keeps blowing Doug G Pneumatics 7 20-02-2007 06:32
Current reversed on compressor spike controller scottish144 General Forum 20 05-09-2005 07:33
20 amp fuses for Spikes Andrew Schuetze Electrical 8 01-04-2003 22:18
Blowing Relay Fuses archiver 2000 2 23-06-2002 21:57
Blowing fuses/tuning drive train DougHogg Motors 10 23-06-2002 00:24
