Go to Post Slight physical blocks will never stop a good programmer, we can just program around it. - AIBob [more]
Unread 20-02-2008, 23:56
samboydh's Avatar
samboydh samboydh is offline
FRC #0702
samboydh will become famous soon enough
Know any good programs for mac?
I have just acuired a Apple laptop and am in need of a good program that will allow me to cad the robot or program the robot its self. I am wondering if any of you know of a version of the programs that will run on macs.
Unread 21-02-2008, 00:08
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
Rookie Year: 2007
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
Re: Know any good programs for mac?
for cad on a mac your options are pretty limited... i tend to use sketchup for simple stuff (sketchup.google.com), but for the more complex stuff i switch over to the pc for solidworks (i suppose you could use inventor)
if you're willing to taint your mac with xp or vista, you could run solidworks/inventor/mplab/etc no problem
(you should be able to use Eclipse (eclipse.org) or Xcode (ships with your mac, probably on one of the extra install discs) to write the C code, although I have no idea if IFI loader will run on OS X)
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Unread 21-02-2008, 00:46
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
i am running a macbook and doing autodesk inventor.
if you have a intel based mac then you can buy VMware and run windows on the background. If not you can se the free program bootcamp and install a partition of Windows.
Unread 21-02-2008, 01:09
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
There's QCAD, which is okay, but lacks some of the capabilities of software like AutoCAD. It's 2D only, but it's better than nothing.
http://www.qcad.org/qcad.html
There's also "TurboCAD", which I've never used, so I can give no review of.
http://www.cadandgraphics.com/tcmac3...FQ-QGgodH1Mpaw
Alternatively, you can use computer animation softwares, such as Lightwave, instead of actual CAD software to create 3D models of your robot. 116 has used Lightwave in the past for creating their plans for their drive systems and frames.
Being correct doesn't mean you don't have to explain yourself.
Unread 21-02-2008, 10:17
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Stay away from that. It's counter-productive of a production worthy CAD software.
It's like using MS Paint for CAD. Sure it will get the job done, but everyone will laugh at you in industry for using it, and it won't be compatible with anyone/anything.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 21-02-2008, 10:42
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Ashlar-Vellum has a suite of Mac-native CAD applications that are very good. Good enough for SpaceShipOne, anyway.
I've used their Graphite 3D wireframe and its predecessors on Macs for eons. Ashlar was a pioneer in parametric modeling and design, but never was able to match Autodesk's marketing clout.
That said, I think Inventor is a better solution if you have the machine to run it. You didn't say what model laptop you got - if it's Intel, it should run some version of Inventor, though just like with a PC, you need a top spec machine to run the latest version well.
Pete Kieselbach
Unread 21-02-2008, 08:06
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Team Role: Mechanical
Rookie Year: 2007
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
well there is your first problem...
just kidding....
inventor should work, we are using it on my team...
Unread 21-02-2008, 08:16
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
Rookie Year: 2007
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
just kidding....
I have a Mac too, and I read up on inventor and it doesn't work with OSX.
Unread 21-02-2008, 08:27
AKA: Michael
Rookie Year: 2007
like i said....
having a mac is your first problem
Any good ideas for a crate? RyanJK Technical Discussion 5 18-01-2008 15:47
Does any body know any good ways of doing this archiver 2001 0 24-06-2002 00:27
Does any body know any good ways of doing this archiver 2001 2 24-06-2002 00:27
Any Body Know A Good Scouting Software? Joe Matt Rules/Strategy 0 14-01-2002 11:28
