Go to Post Maybe next season I want to develop and test a new metric for FRC scouting: Bumper Quality Rating (BQR). BQR-5: The platonic ideal of FRC bumpers. ... BQR-0: Moderate to heavy use of duct tape. I believe BQR would outperform OPR as a predictor of on-field robot performance. - Nate Laverdure [more]
Go Back   Chief Delphi > Other > Chit-Chat > Games/Trivia
Unread 22-02-2008, 16:11
Ctrl Alt Delete's Avatar
Ctrl Alt Delete Ctrl Alt Delete is offline
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Ctrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to behold
Send a message via AIM to Ctrl Alt Delete Send a message via MSN to Ctrl Alt Delete
The FIRST Name Game!
No, this isn't next year's Kickoff game show. It's a small game developed by myself and Chris Jelly. The pressure is on as you have 10 seconds to figure out which team is right!
http://www.bobcatrobotics.org/teamguess/
Team data comes straight from The Blue Alliance's newly-announced API.
Remember to post your high scores here!
Life lessons learned at robot:
1.) Never take apart power strips
2.) Sleep is required, but not essential to survival
Failure to abide by these lessons will result in headaches...and flaming pants.
"Here at Bobcat Robotics, we pride ourselves in having 60-table MySQL databases, girlfriend cookies, and a vinyl cutter." -Chris Jelly
Unread 22-02-2008, 16:16
Scott Carpman's Avatar
Scott Carpman Scott Carpman is offline
FRC #1155 (SciBorgs)
Scott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud of
Re: The FIRST Name Game!
The game is a bit off...must be a code problem.
I was asked the number of two teams that I'm very familiar with (Hawaiin Kids and R7) and of the 4 choices, none of them were the correct number.
RPI '12
Unread 22-02-2008, 16:30
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
I just had the same problem.
It asked for the number of Team 500, but 500 wasn't a choice. When I picked a choice it said the correct answer was 500.
Otherwise great way to waste time
By the way it was definitely a mechanical problem, its never the programmer's fault.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Last edited by Branden Ghena : 22-02-2008 at 16:31. Reason: had to reply to the comment above me
Unread 22-02-2008, 16:31
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
I got the same thing, not having a right choice of numbers for the team name.
Unread 22-02-2008, 16:34
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
I just got Hawaiian Kids come across and 359 was indeed an option.
EDIT: Now I see what people mean. I'm trying to figure it out now.
Unread 22-02-2008, 16:37
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
I also got this issue for some teams that I know.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 22-02-2008, 16:40
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
If everyone can try it again. I think it's fixed.
EDIT: You can't refresh manually. You have to let the timer run out to clear the session.
Unread 22-02-2008, 16:47
Devibeast's Avatar
Devibeast Devibeast is offline
Incase U wre wondrn this is a Hammr
AKA: Sri
FRC #0025 (Raider Robotix)
Team Role: Student
Devibeast is an unknown quantity at this point
Pretty cool, how long did it take you?
Raider Robotix
-Nothing is Beyond our reach
Unread 22-02-2008, 16:52
Yep, it's fixed now.
I think I know how to make this better (hint: it involves more of the API).
RPI '12
Unread 22-02-2008, 16:53
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
It actually took about 30 minutes with everything. The problem people were having should be fixed. Use the skip button instead of refreshing with F5 or your browser button because it screws up how the game tracks the correct answer.
Unread 22-02-2008, 17:07
Eric O's Avatar
Eric O Eric O is offline
AKA: Eric O'Brien
FRC #0177 (Bobcat Robotics)
Rookie Year: 2000
Eric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond repute
Send a message via AIM to Eric O Send a message via Yahoo to Eric O
Dave,
You make this so it queries data for a given competition. It would be a good way to students (and mentors for that matter) to learn the teams from a regional/division and therefore be more informed when scouting teams.
-Eric
Eric O'Brien
Team 177 - Bobcat Robotics (00-01,06-?)
Team 229 - Division by Zero - Clarkson University (02-05)
Unread 22-02-2008, 17:10
!aaaaa! !aaaaa! is offline
Junior Member
no team (the greatest team ever)
Team Role: Mascot
!aaaaa! can only hope to improve
thats a good idea the judges will like that
Unread 22-02-2008, 17:34
Originally Posted by Eric O View Post
Dave,
-Eric
I was thinking the same thing, with the addition bit of having the robot picture of the correct answer shown.
RPI '12
Unread 22-02-2008, 17:42
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
Fun game! I got 20.
It might be better if it only took away one point when you get a wrong guess, instead of taking away all your points.
It seemed like it wasn't completely random. I got the same ones again several times over.
  #15   Spotlight this post!
Unread 22-02-2008, 17:43
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
I had an extinct team number come up as one of the choices.
(since 2004)
Poll: FIRST Video Game Name Bcahn836 FIRST-related Organizations 17 22-06-2004 22:48
FIRST video game the name... Ryan M. FIRST-related Organizations 41 17-06-2004 10:17
Name of the Game????? archiver 2000 13 23-06-2002 22:27
