Go to Post Coming between me and my Hawaiian shirts would be like trying to get between Dean and denim. - dlavery [more]
  #31   Spotlight this post!
Unread 24-02-2008, 13:55
Vexkingof716's Avatar
Vexkingof716 Vexkingof716 is offline
WHOS'CTEKS Driver
AKA: Cowpots
FRC #0716 (Who'sCTEKS)
Vexkingof716 has a spectacular aura aboutVexkingof716 has a spectacular aura about
Re: Too much traction
You should try the omni wheels. they work really well for us. In the past we had the same problem. This year we bought the Andy mark aluminum omni's. Our set up is omnis in front and 2 inch wide wheels in back. Front and back are powered. It has worked really well. At the Suffield scrimmage we were really fast going around the track, at the same time we could push fairly well. If you cant get the omnis try the KOP wheels. they might work well also.
  #32   Spotlight this post!
Unread 24-02-2008, 16:43
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
Team Role: Coach
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
go omni or i don't no if this is a good idea but take the robot and jack it off the ground and sand down those wheels i never used those wheels so i don't no if that is possible... and be careful if you do this.
  #33   Spotlight this post!
Unread 24-02-2008, 16:53
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Thank you everyone, with all of these we will find a solution to your prob.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
  #34   Spotlight this post!
Unread 24-02-2008, 17:11
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Heres a simple solution. Order some AM Plastic Omniwheels. Bring them to the competition. They work with the same bearings as the traction wheels I believe and have the same sprocket mounting pattern. Put omni's on two of the corners (front left and back right or FR+BL) and it should help turning without being really wild. If you still don't have the turning you like, then put the omni's on the front. You shouldn't break chain unless you didn't align them correctly.
I would advise finding the drawings for the plastic omniwheels on Andymark's site and comparing dimensions with the IFI Traction wheels you are using so you can make new spacers before the competition.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
  #35   Spotlight this post!
Unread 24-02-2008, 17:42
Martijn Martijn is offline
Engineering Captain
FRC #1414 (iHOT Robotics)
Team Role: Leadership
Martijn is an unknown quantity at this point
we had exactly the same problem last year. if you can't replace the wheels once you get to regionals, would either flip over the tread on the front or back wheels. wrapping them in duct tape, and putting lots of zipties around them might work even better. hope you can fix it once you get there, ours were simply a disaster last year.
  #36   Spotlight this post!
Unread 24-02-2008, 19:12
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Originally Posted by DarkFlame145 View Post
Thank you very much everyone, I was just talkign to a mentor and we now have a few things we will try:
1) Move the center wheels to change the wheelbase
2) Use a 1” wide wheel for 2 of the wheels which will reduce the friction (less wheel tread on the carpet)
3) Raise or lower the casters.
4) Install larger casters
5) Replace a wheel set for a pair of omni wheels
6) Change the wheel tread to lower friction type
7) Change the gear ratio of the drive
8) Install larger wheels on the left side of the robot (old dirt track stock car trick)
Number 8 is my personal fav cause it keeps in the spirit of the bases of this years game
1> Will work as long as the movement is to shorten the wheelbase
2> Reducing the wheel width will not gain much as Coefficient of friction has not changed
3> Will work, but be careful of reducing the contact of your wheels or you may go too far and end up with no traction on your center wheels (and end up hitting the walls).
4> Same as 3 with no adjustability
5> This wil work for turning ... but be careful if you do this with your wheels in the center of your bot as you may end up just swinging the rear out when you turn with little control at higher speeds
6> Will work, but will need some experimentation to find a good CoF wheelset
7> Will work as long as it's a slower gear ratio
8> Will make the bot difficult to drive straight.
Good luck, I'd suggest changing the center tires to ones with a lower CoF
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
  #37   Spotlight this post!
Unread 24-02-2008, 21:08
That guy
AKA: Dennis
We could set the joysticks to counter react the pull of the wheels. So when we push the joysticks forward it should go strait.
Too much code MARS-CJ Programming 2 22-04-2006 17:34
Too much torque? Ctrl Alt Delete FIRST Tech Challenge 2 07-03-2006 01:55
Pneumatic Wheels -> Too Much Traction OldDan1168 Technical Discussion 2 24-02-2004 11:28
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
