Go to Post Remember that it's not what is on the outside of the shirt that matters, it's what is on the inside. - dtengineering [more]
Unread 23-02-2008, 18:21
octothorpe's Avatar
octothorpe octothorpe is offline
AKA: Nick Felt
FRC #0766 (MA Bears)
octothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to behold
766 Robot 2008
This is what we rolled out the door at 9pm on Monday night:
As you can see, there's still some finish-up work left for Thursday at the first regional (i.e. decals and attaching the bumpers!), but this year the design has come together quite nicely and we anticipate a successful season.
A few features:
Drivetrain
- Powered by 4 small-CIMs via AndyMark 2-speed transmission
- Uses six 3.7" custom wheels to achieve a lower profile
- Designed with monocoque construction principles in mind to reduce size, avoid cantilevering, and protect the drivetrain – the two main beams are 2x3" box tubing with holes milled out
- Uses 25 chain between wheels and 35 chain from transmission to center axle, with horizontal axle adjustment for tensioning
Elevator *
- 3 stages, forks can reach a height of 7 feet in under 3 seconds
- Employs continuous cabling to keep the center of gravity low
- Uses Spectra cable for flexibility and light weight
- Custom bearing setup does not require use of 80/20 extrusion
- Powered by 2 Fisher-Price motors with AM planetary and Toughbox
Manipulator
- Forklift-style prongs to support ball from below
- Pneumatically-actuated hoop constructed from fiberglass poles to capture the ball
- The nearer half of the ball rests within the confines of the robot when grabbed, ensuring stability and ease of turning while the robot is carrying the ball
General
- Frame is TIG/MIG welded aluminum, weighs approx. 30 lbs. without elevator stages
- Low center of gravity due to placement of just about everything in the bottom of the robot
- Total weight: 119.2 119.6 lbs (those decals will push us over... )
- Total height: 60" (no joke... hopefully it will shrink in the crate)
I should also credit our electronics, pneumatics, programming, and OI construction crews for their excellent work. Although harder to appreciate either in this picture or from a strategic standpoint, their jobs are also of utmost importance.
* In regards to the elevator, we would like to thank Team 254 for allowing us to borrow elements from their excellent design of last year. Your work is always an inspiration.
So now all that remains is to name the robot... any suggestions?
- Nick
Unread 23-02-2008, 19:58
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
Re: 766 Robot 2008
Drunken Squirrel (Nicole's)
Caffeinated Squirrel (mine)
The Guillotine (more appropriate as elevator name)
Walrusbot 2.0 (remember Walrusbot 1.0? From '06 Phlebus the Transformer/Whambulance/Informer)
Invisible Rogue (Referring to the hidden chain; will it be difficult to maintenance?)
And likely more to come!
Note: That yawning cavern in the background is our infamous Closet, with self-built welding screen and scrap box in sight. It is perpetually organized chaos, the inspiration for many a limerick, and the rookie initiation with cleaning, sorting, and introduction to safety (here are the safety glasses/this is the soldering iron- this is the hot end).
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 23-02-2008, 20:20
razor95kds's Avatar
razor95kds razor95kds is offline
razor95kds has a spectacular aura aboutrazor95kds has a spectacular aura aboutrazor95kds has a spectacular aura about
Re: 766 Robot 2008
Nick we actually are 119.6 (dad weighed it right before ship) and we are missing some 1/4- 20 bolts for the bottom plate so we have no weight for decals . Hooray for speed holes in our armor!!!
2005- Davis- Sacramento Regional Champions (w/245 and 1072)
2005- Silicon Valley Industrial Design Award Winner
2005- Archimedes Divison Champion (w/245 and 217)
2006- Silicon Valley Regional Champions (w/254 and 581)
2007- Silicon Valley Regional Finalists (w/488 and 852)
2007- Alliance captain of only alliance (w/488 and 852) ever to defeat 254 at SVR
Unread 23-02-2008, 21:54
octothorpe's Avatar
AKA: Nick Felt
Re: 766 Robot 2008
119.6 !?
And we don't even have decals or all those bolts in. Besides, don't forget that the camera still isn't on the robot, and although I know it's not crucial it'd still be really nice to get it onboard. Not to mention beads for the elevator drum. We may have to do more than just cheesehole polycarb. That air cylinder on top has always been too heavy for my tastes...
Unread 23-02-2008, 22:39
burkey_turkey burkey_turkey is offline
AKA: Andrew
FRC #0422 (MechTechs)
Team Role: Mechanical
burkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to behold
Re: 766 Robot 2008
That looks like a sweet bot. We have an elevator on ours as well, but we had trouble powering the cables (continuous like you guys). Could you go into more specifics on the design of the elevator, im very curious. Once again, solid design guys, thats fantastic work!
Unread 24-02-2008, 00:01
octothorpe's Avatar
AKA: Nick Felt
Re: 766 Robot 2008
Thanks! I'm glad you like it. Unfortunately most of the elevator mechanisms are hidden in this picture, but you can see some of it near the bottom of the robot towards the front. There are two blue shiny things which are the AndyMark planetary gearboxes that we used to adapt the Fisher-Price motors to the AM Toughbox (about a 46:1 reduction in total). This gearbox chain-drives a polycarbonate tube (visible in the photo just beneath the gearbox) mounted between the towers which acts as the drum to wind cable. We positioned the drum with the axle running front-to-back so that as the drum spins, it pulls in cable from either side. These cables go out to the towers flanking the robot and loop through a total of 8 pulleys on the different stages to form the continuous lift.
Unread 24-02-2008, 00:16
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
Team Role: Leadership
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
Talking Re: 766 Robot 2008
that is pretty cool, it's looks like one of the designs we were contemplating using, until a different idea came up of course, lol, that's awesome .
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
pic: 766 Teaser #1 razor95kds Extra Discussion 5 05-02-2008 23:54
Team 766 Robot *On-board* Video octothorpe Robot Showcase 23 17-04-2007 01:05
pic: 766 Teaser Sterno Robot Showcase 12 09-02-2006 01:01
Thank you 245 and 766 Alex1072 Regional Competitions 0 06-03-2005 18:45
pic: 766 lifting a goal razor95kds Robot Showcase 2 22-02-2005 16:40
