How to make a custom OI switch box
I don't know anything about this or have any clue on how to do it.
I think i need the pin layout and like everything else Step by step instructions would be great! Thanks |
Re: How to make a custom OI switch box
This should help: http://www.thebluealliance.net/blog/...stom-controls/
It will tell you which pins correspond to which buttons. Then you will connect each button to ground to connect the switch. ex, you would connect p4_sw_trig [Pin 2]on one end of the switch and ground[pin 4 or 12] to the other side. You can use 22 gauge solid wire to stick directly into the oi, buy pins, or cut off the end of a joystick 15 pin connector. |
| Using Transistors in Custom OI box? | Precious | Control System | 2 | 30-01-2007 15:24 |
| How to create a custom operator interface box? | JWilliams101 | Control System | 9 | 27-02-2005 23:13 |
| Beacon selector switch? How to find/make? | Fen | Programming | 13 | 12-02-2004 16:31 |
| Custom Control Box | D.Viddy | Programming | 3 | 15-02-2003 11:35 |
| Custom Electronics Box | doteman | Electrical | 4 | 10-04-2002 11:35 |
