Go to Post OK, repeat after me "FIRST is not about the robot". - Foster [more]
Unread 25-02-2008, 22:32
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
Team Role: Leadership
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
Parker Valve
I just wanted to warn people that your parker discharge valve may fail. Our last test before ship the whole system would not charge because the valve was not sealing off in the closed position. luckily we have a parker distributor in town who told me that they are having issues with that valve and that the PV609-2 is being replaced with the MV609-2 which seals better and is less effected by corrosion. He can no longer get the PV version. I hope that FIRST is OK with it, they say and identical valve is fine, and they guy at Parker told me to call him if we had any issues with them. Just wanted to warn people because it would be a shame to see someones robot fail because the $15 valve failed (glad ours failed when it did).
Good luck in the regionals ahead. See some of you in portland
A2D Solving the Imaginary Error Function...
Unread 25-02-2008, 23:02
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: Parker Valve
The PV609-2 is still in the Parker catalog. You should still be able to get the valve directly from Parker.
1-800-C-PARKER
(1-800-272-7537)
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 25-02-2008, 23:07
AKA: Brennan Ashton
FRC #2605 (A2D_16)
Re: Parker Valve
perhaps, but it is being removed for the part i mentioned because of these issues. This is why he cannot get it.
Unread 25-02-2008, 23:14
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Parker Valve
Sorry, I wasn't disagreeing with you ... just pointing out another possible source for the part since FIRST tends to be very picky about the pneumatics components in the robots.
___________________
- Tennyson, Ulysses
Unread 26-02-2008, 01:31
AKA: Brennan Ashton
FRC #2605 (A2D_16)
Re: Parker Valve
Ok, we are checking with FIRST on the Q & A
pic: Donated Parker Valve Andrew Schuetze Extra Discussion 8 02-10-2012 22:31
Parker 1.5x8 Cylinder customh Pneumatics 2 09-02-2007 03:41
Modifying Parker Cylinder Coachmac Pneumatics 6 16-02-2005 21:41
What is the Difference between Parker and Bimba generalachoo Pneumatics 3 23-01-2005 16:58
Question about Parker Component theCowboyKnight Pneumatics 1 20-01-2005 16:59
