Go to Post Own your words. - Joe Johnson [more]
Unread 28-02-2008, 18:59
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
"Pulling" a pin low
Does this mean to short it out?
For instance, we've currently got our maxbotix sonar in constant polling mode. If I wanted it only to check distance on command, would I hook up the RX pin to a digital output, or a relay, and turn it on?
I'm a little confused about the terminology.
http://www.maxbotix.com/uploads/LV-M...-Datasheet.pdf
Unread 28-02-2008, 19:41
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: "Pulling" a pin low
It'd be preferable if you shorted the pin to ground through some non-zero resistance, but that would be one way. The datasheet actually says to hold the pin low to disable ranging, which is a slightly different concept from a pin being pulled. To "hold" a pin low or high, you apply either GND/Vss/low voltage or Vcc/high voltage to it, depending on labeling conventions, etc. So the only requirement to stop the ranging is to apply 0V to the RX pin in whatever fashion you choose. You could simply hook a digital output to the RX line and set it to 0 when you want ranging off. Using a spike would be more complicated and would also necessitate using 12V instead of 5V as the high voltage which would probably fry things.
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Rookie Year: 2007
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
Holding a pin low should mean connecting it to ground. You should be able to do so by hooking the pin up to a digital IO in output mode and setting it to 0 when you don't want the sensor to run.
(Granted, I've never actually used the digital IO as outputs, but that's what should work how I understand it.)
Last edited by Daniel Bathgate : 28-02-2008 at 19:42. Reason: terminology fix, and I was beaten to it
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Wiring "3-pin" Shaft Encoder. Joel J Programming 7 27-02-2004 17:21
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
