Go to Post And, if you don't know what something means, say so, we'll be happy to explain. - DonRotolo [more]
Unread 28-02-2008, 21:20
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Day 1 Week 1
Just a few questions for everyone who have first week regionals:
What was different than expected(defense, mobility, etc.)?
Any cool designs that someone on your team thought of then you said "pfft that's cool but impossible"?
How did IR work in general?
Were lap counters reliable?
Also any little problems or things that weren't expected, like rules and things like that?
Unread 28-02-2008, 21:27
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
Rookie Year: 2007
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: Day 1 Week 1
Yes, don't leave us in the dark!!! I've got three more weeks to prepare, give me the details. Photos welcome.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 28-02-2008, 21:41
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Rookie Year: 1997
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Re: Day 1 Week 1
As stated in our "unveiling" thread- we had two problems caused by the field today
First- the height dimension for the overpasses has been getting lower and lower. By days end the sag had them down to 76" from the floor. A number of robots, including us, want to clip the bottom of the ball just under the overpass to pop it up. So if you counted on a more or less 78" be wary because it may be way off from that. We slammed the crossbar on our first outing and spent the rest of the day trying to finagle some solution to this inconsistency.
Second- Our IR system worked flawless at home. We pointed a dozen different remote controls at it, shot it through windows, pipes, cupped hands- well you get the picture. In the pits it worked like a charm.
On the field it suddenly became erratic and lost signal. Hmmm. After an afternoon of anguish we found the culprit- that damned flag beacon. The IR system to count the laps was mounted right next to our receiver and the beacon was blasting the system. We cut power to the beacon and it worked fine. So we moved the receiver and shielded it and that seems to work fine. Thanks to 1676 for the button we formed into a beacon shield.
As for game play- picture driving at rush hour when you are in a hurry to get home. Everybody- arm or no arm- needs the walls to corner the ball. And there is fair arm to arm contact.
Everybody is velcroing their control systems to the operator station because runaway robots in autonomous are smashing the far walls and tossing the controls off the shelf.
Overall the game is not as wonderful as I would have hoped.
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 28-02-2008, 21:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Day 1 Week 1
Thanks for the info! We are used to a sagging overpass, since I made our test one out of too small of pipe....I guess our pool noodle ball knocker offer idea wasn't so flakey after all. And we have our IR receiver mounted low on the robot, but it might need some shielding.
Unread 28-02-2008, 21:50
Branden Ghena's Avatar
Branden Ghena Branden Ghena is online now
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: Day 1 Week 1
What kind of shielding could you use for an IR sensor? Would plastic stop signals, or would you have to use sheet metal?
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 28-02-2008, 21:54
MrForbes's Avatar
AKA: Jim
Re: Day 1 Week 1
Do you have a TV? and a remote control? do some experiments!
(and let us know what you find)
Unread 28-02-2008, 21:57
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
Rookie Year: 2007
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
Re: Day 1 Week 1
I don't have an answer to your question, but if you want to test a material to see if IR light passes through it, take a newer video camera with nightshot and look at your remote while sending signals. Put a material you want to test between the camera and the remote annd then see if you can still see the pulses.
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 28-02-2008, 22:18
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Team Role: Leadership
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
Re: Day 1 Week 1
Another option is if you have a camera phone or really cheap digital camera you will be able to see IR pulses through it.
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 28-02-2008, 22:32
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
Re: Day 1 Week 1
Before we shipped our robot, we added a layer of Lexan on the robot. It was also in front of the IR board. It worked fine, so I don't think Lexan affects an IR signal that much.
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Unread 28-02-2008, 23:20
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Re: Day 1 Week 1
I agree. We made a lexan case for our IR receiver and no problems receiving signal.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 29-02-2008, 07:35
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Team Role: Mechanical
Rookie Year: 2007
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
Re: Day 1 Week 1
ok now i am worried. i am a week two regional, and have some concerns. first off he have fiberglass grippers that go around the outside of the ball and i am concerned about them snapping off since people say that there is a lot of arm to arm contact. also during testing at home, we forgot to pick the wheels up off the ground when loading the program, and it shot forward (while still tethered) and we ended up herding a table! has anybody broken their arms yet...
like i said we are using fiberglass grippers that i molded, which are only 2 or 3 layers thick, with a plywood rib on the back...
does anybody think there will be a problem?
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
Unread 02-03-2008, 10:00
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
Rookie Year: 2007
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Day 1 Week 1
Three things I noticed about game play that I didn't expect:
1. There is a lot more defense then I had anticipated, needless to say it doesn't even compare to last year.
2. All good alliances need a good shooter.(if you don't have to stop to hurdle you have a big advantage over everyone that needs to stop)
3. Hybrid mode is very important because I have seen a lot of struggling just to pass two lines. The teams that I have seen that pass 3 or more lines in hybrid consistently seem to be very successful.
Unread 28-02-2008, 22:08
waialua359's Avatar
Mentor
AKA: Glenn
Rookie Year: 2000
Re: Day 1 Week 1
In sports people want excitement and want to see lots of scoring.
I think that's what made it so exciting to watch the dominating robots in 2006. This game is much different.
After watching video footage today, it looked like someone played a VCR tape and kept it on slow motion (with the exception of speedy bots)
As predicted, grabbing/grasping the ball is tough and doing it with great efficiency is just as important as scoring efficiently, if your a hurdler.
Easy for me to watch it on video,.....must be something else for the student controllers trying to play the game.
Unread 28-02-2008, 21:55
synth3tk's Avatar
AKA: David Thomas
Rookie Year: 2007
Re: Day 1 Week 1
WC
Hmm, well, it's one person's opinion so far. But thanks for the detailed update. Correct me if I'm wrong, but it sounds like it's a pretty hectic free-for-all.
  #15   Spotlight this post!
Unread 28-02-2008, 21:59
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Day 1 Week 1
I very strongly recommend that everyone pay attention to this. Wildstang's control board went flying today after an exceptionally fast robot hit their driver station in hybrid mode. I know they won't be the last to experience this.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
MOEmentum: Week 3 - It's Week 3 Already? Mr MOE General Forum 3 22-01-2008 10:16
End of Day 1 (Thursday practice day) Ryan Albright General Forum 11 17-04-2004 22:31
Day 1... Pin Man Chit-Chat 34 11-09-2003 16:49
Happy St. Patricks Day (also known as MOE green day) Joe Matt Chit-Chat 4 18-03-2003 14:17
FIRST to reduce 6-week building period to 5-week archiver 2001 12 24-06-2002 01:27
