Go to Post Never quit, never give up, never say die! - Cascade [more]
Unread 29-02-2008, 17:13
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Rule G22 needs to be changed
I think rule G22 needs to be changed. There are way too many penalties for breaking this rule and it's sucking the fun out of the game. It's so easy to violate this rule that most teams don't even know they've done it. Does anyone else feel this way?
My suggestion: change the rule so that it says that once you've fully entered a new zone, you cannot fully return to the previous zone. Example, if I completely cross the blue line, but then back up a little bit so half my robot is over the line, no penalty. However, if I continue to back up and fully cross the blue line in reverse, then the penalty is assessed.
I believe this would maintain the intent of keeping the traffic flowing in the correct direction but greatly reduce the number of penalties for incidental contact with a line after it's been crossed.
Way too many matches are being decided by penalties this year and that's not fun for the teams or the audience.
Unread 29-02-2008, 17:15
SU 39 SU 39 is offline
AKA: Andrew Su
FRC #0846 (Funky Monkeys)
SU 39 will become famous soon enoughSU 39 will become famous soon enough
Re: Rule G22 needs to be changed
I agree completely. It's difficult enough as it is to drive a robot amid all the traffic. I just saw a match where a team had 50 points worth of penalties, taking their 40 something score down to 0, giving the other alliance the win with only 20 or so points.
Unread 29-02-2008, 22:34
acetech-st acetech-st is offline
FRC #1850 (Mechanicat)
Rookie Year: 2007
acetech-st is an unknown quantity at this point
Our Alliance scored 48 and had 50 points in penalties. We lost a match 0-6.
We're still not clear on where or when the penalties were assessed.
It would be nice to know how this is being called so we could try and prevent it from happening
Steve
www.acetechnical.org/
FRC Team 1850 - 2007 MIDWEST Regional Champions
Unread 29-02-2008, 17:16
Software Engineer
Rookie Year: 1995
For those who don't know G22:
<G22> Direction Of Traffic – ROBOTS must proceed around the TRACK in a counter-clockwise direction. Once a ROBOT has CROSSED a LANE MARKER or FINISH LINE, it shall not break the plane of the line by moving in the clockwise direction. A PENALTY will be assigned for each infraction.
Unread 29-02-2008, 17:17
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
I totally agree. It seems like upwards of 50% of the violations are occurring because teams get halfway into a new zone and encounter some sort of obstruction and need to back up to get around, and inadvertently get the penalty, or they try to pick up a ball while halfway in a new zone, etc.
2001-2004: Team 100
2006-Present: Team 254
Unread 29-02-2008, 17:20
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
I get this feeling watching the webcasts as well. Between the ability to control the robot itself and the ability to see exactly where your robot is at on the other side of the field, it appears to be very difficult to get around traffic around the lines without getting a penalty.
With the large magnitude of a single penalty with relation to the magnitudes of the scores (at least 10% and anywhere up to 30%-50%) penalties appear to be deciding far more matches than they should.
Your suggested modification looks like it would keep traffic moving in the correct direction while getting rid of many of the penalties.
Unread 29-02-2008, 17:32
Ross340 Ross340 is offline
It's all food in the food
AKA: Ross
FRC #0340 (G.R.R.)
Team Role: Driver
Rookie Year: 2007
Ross340 will become famous soon enoughRoss340 will become famous soon enough
I totally agree. It leaves arm robots at a loss. If they're required to cross to hurdle. I've seen a bunch of this.
Unread 29-02-2008, 17:35
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
The initial crossing is already as written in Dave's suggested modification.An arm bot crossing the finish line to hurdle (having an appendage behind the overpass to hurdle I would assume) should be able to back up into the quadrant they were just in without penalty.
Unread 29-02-2008, 17:52
Mike o.'s Avatar
Mike o. Mike o. is offline
AKA: Mike O'Brien
FRC #1086 (Blue Cheese)
Mike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud of
Send a message via AIM to Mike o. Send a message via Yahoo to Mike o.
Robots do not get penalized until they have FULLY CROSSED the line, meaning that every part of the robot is in the new quadrant, and then their robot crosses/breaks the plane of the line in the clockwise direction. I think that the rule is pretty good the way it is set up. I do believe that teams should start to think outside the box when it comes to encountering traffic jams, meaning that if a robot is sitting there and not moving, and you can't move cause if you back up or the only way you can move will cause you to incur a penalty, then bump the robot to pass. If the robot doesn't move in the 6s grace period, they will get penalized. And if they continue to do this, they will according to G41 get a yellow card or probably penalized more.
just my 2cents
Mike O'Brien
Founder, Almuni, & Mentor Team 1086
2010 GAL Division Finalist & Coopertition Award; NC Regional Winner & Quality Award; VA Regional Winner & Engineering Inspiration Award Winner
2009 CMP Team Spirit Award; VA Regional Winner & Chairman's Award
2008 VA Regional Winner & Chairman's Award
2007 & 2006 VA Delphi "Driving Tomorrow's Technology" Award
2005 VA Team Spirit Award; 2004 VA Imagery Award; 2003 Rookie Year
Unread 29-02-2008, 17:58
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Team Role: Leadership
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
They've made Rule changes after week 1 before. Dave....
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 29-02-2008, 21:10
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
Dave,
I have to disagree with you on this one. It is a rule like any other. The rule was clear from the start. Either don't fully cross the line, or once you cross it, then keep going.
BTW, one of our losses today was due to a partner getting this penalty. If the rule was changed to fully crossing back, then teams would violate that rule too.
-Paul
Unread 29-02-2008, 21:17
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Its not one of the rules thats meant to spoil the fun, its an element of the game designed to make it harder. with this rule in place, the game becomes more challenging.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 29-02-2008, 21:23
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
I believe that removing the penalty attached to this rule would be too much of a change in gameplay. Maybe a better amendment would be to make it 5 points? 2 points?
I will admit though, the rule is really quite annoying- we lost a couple of matches due to alliance partners getting penalized.
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 29-02-2008, 21:30
Jazonk's Avatar
Jazonk Jazonk is offline
It's all a balancing act.
AKA: Dino
FRC #0027 (Team RUSH)
Team Role: Driver
Jazonk will become famous soon enough
Send a message via MSN to Jazonk
I think you are completely right, the penalty is too high.
  #15   Spotlight this post!
Unread 29-02-2008, 22:39
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
I have mixed feelings about this. I mean, it's not too hard to avoid if you know what you're doing. Nonetheless, having a team get blasted 50 points in a match (I saw this once on the webcast) because someone crossed the line is also excessive. It's not like they gained 50 pts of unfair advantages by doing so...
Especially in autonomous mode, i think it's excessive. It should also be limited to when the team has anything to gain in teleoperated mode.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
G22 Direction of Traffic Hilarity Kevin Sevcik Rules/Strategy 16 17-01-2008 22:30
problems with G22 JMH Electrical 2 19-01-2005 20:52
VB changed my capitalization! Greg Ross CD Forum Support 3 25-02-2004 15:42
Rule G11 and Springs Rule mtaman02 Technical Discussion 3 23-01-2004 17:43
A Changed F.I.R.S.T Vin211 General Forum 0 26-09-2001 22:39
