Go to Post Engineering is so much easier when you give all the components personalities. Then you just watch the drama unfold and try to fix it. - EricVanWyk [more]
Unread 29-02-2008, 22:00
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
pic: FIRST Overdrive Score Distribution
Unread 29-02-2008, 22:01
Mike Starke Mike Starke is offline
FRCTop25.com
Mike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond repute
Re: pic: FIRST Overdrive Score Distribution
Ok, I know this may sound dumb, so i'll take one for the team.
Can you explain what this chart means? I'm having trouble putting 2 and 2 together. Thanks!
Unread 29-02-2008, 22:05
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
basically it shows the number of scores that have occurred between a said range... i.e. there are 26 scores today that were between 0 and 10.
Unread 29-02-2008, 22:11
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
I think the confusion comes from it being a bit mislabeled (or at least confusingly labeled). It looks like a normal old normal probability density curve with the Y axis being the number of matches in a range of scores, such as 94 matches being between 40 and 49.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 29-02-2008, 22:16
Scott Carpman's Avatar
Scott Carpman Scott Carpman is offline
FRC #1155 (SciBorgs)
Scott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud of
And the whole "bins" label doesn't help with the confusion. I get the general gist of it though, great work.
RPI '12
Unread 29-02-2008, 22:20
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
1519's scouts tell me that the average score per team per match at BAE is 14.70
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 29-02-2008, 22:23
in between teams
AKA: Luke Van Oort
Hmm... thats really low. I guess that's to be expected of a week 1 regional. Try asking your scouts what the median of the data is. I suspect that that will a more accurate idea of the what the matches really are like.
Unread 01-03-2008, 06:53
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
That's per TEAM per match. So the average score is 14.7*3=44.1 which is certainly higher than I expected.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 01-03-2008, 06:18
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
Team Role: Leadership
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
Thats probably close to correct. The date is slightly skew (shewed left to be specific), so the mean will be higher than the median.
Unread 01-03-2008, 01:38
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
I had to check to make sure it wasn't from 2003.
Interesting though once you figure it out, it's right about where a lot of people said it would be.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 01-03-2008, 04:11
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Rookie Year: 1997
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
where was the 110 + scored?
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 01-03-2008, 07:53
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
WC
I don't see that score registered anywhere either.
(since 2004)
Unread 01-03-2008, 08:27
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
I thought the top score was 104, which would put it in the 100 bin. (assuming the 0 bin is 0-10 points)
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 01-03-2008, 08:31
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Hmm, is the first bin 0 (exactly), and the second bin is 1-10? That would explain it - but the OP should revise the chart to indicate it properly.
(since 2004)
  #15   Spotlight this post!
Unread 01-03-2008, 08:52
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Rookie Year: 2000
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Overall or winning alliance score distribution?
Great work!
Manoel Flores da Cunha
Mentor
Brazilian Machine
Team # 383
**FIRST EMAIL**/Revved up for FIRST Overdrive! Mark McLeod FIRST E-Mail Blast Archive 0 26-02-2008 09:45
FIRST Overdrive field in Inventor pmax Inventor 20 05-02-2008 20:02
FIRST Overdrive logo Kevin Thorp 3D Animation and Competition 6 28-01-2008 09:12
FIRST Overdrive Animation RyanCesiel General Forum 15 09-01-2008 00:41
Video of FIRST Overdrive match. Madison Chit-Chat 2 07-01-2008 20:16
