Go to Post STEM blushes, and asks if Art would like to go out for a date. - Cothron Theiss [more]
Unread 01-03-2008, 13:32
magnotta magnotta is offline
FRC #1568
magnotta is an unknown quantity at this point
easy-c program wont download
just installed easy-c on laptop for vex challenge tomrrow - when we try to download a program, my usb/com port teather is not recognized. what do I need to make this work
thanks
Unread 01-03-2008, 13:34
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: easy-c program wont download
Have you installed a driver for the usb teather?
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 01-03-2008, 14:06
FRC #1568
no, where can I find the driver?
Unread 01-03-2008, 14:08
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
I fixed Elie's this morning, Click on the start menu, right click my computer. click properties, click the hardware tab then click device manager if you scroll down that list you should see COM Ports, see what number com port is right under that then enter that in Easy C where ever you can change connection options for the loader.
If your com port is set correctly then download the driver from here http://www.chiefdelphi.com/forums/sh...ad.php?t=46174 and see if that fixes it.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 01-03-2008, 14:17
FRC #1568
nevermind - found it
How to download program to robot? Hazmatt Programming 16 19-01-2008 22:14
easy c default program? bos1ex Programming 9 30-01-2007 22:12
program download question. Tachion Technical Discussion 1 27-10-2005 10:49
program download problem zdeswarte Programming 5 23-03-2005 06:46
Crashing on program download Ryan M. Programming 3 01-02-2005 21:15
