Originally Posted by Anne Shade
Actually Dan,
The team was warned during Qualifying matches, not eliminations. When teams enter eliminations, their slate is supposed to be wiped clean. However, this year's yellow card is to be given for "egregious" robot or team member actions. If the head ref thought the one time was egregious, the yellow card could have been given. That is up to that particular head referee's interpretation of the action. I'm not sure exactly which rule the head ref believed was violated "egregiously" in this case because I can't seem to find one. I guess you could lump it under S01...
My question is whether or not the timing of the yellow card was appropriate. The yellow card was given during the reset of the match. To me, that would mean the match had yet to be completed. Can a team receive a yellow card for a match that had yet to be completed? What if their robot had again rammed the player wall when they replayed the match, would the alliance get DQ'ed for receiving a second yellow card in the same match?
This kinda follows Dez's point about the time out being called during the middle of the match...
I totally agree with you about the timing issue - the Head Ref should've technically waited until after the match had completely ended before giving out a yellow card. Your second hypothetical is moot because generally a yellow card is severe enough punishment to correct the behavior or at minimum abort the hybrid strategy as to not risk getting a red card.
There is no rule that says that the "slate" is wiped clean for eliminations, only that cards do not carry over into eliminations. Unofficial warnings are given to prevent egregious behavior throughout the entire competition, and aren't official rulings on the field. The head ref might've thought that the team was performing programmed egregious behavior the first time, but gave the chance to correct the programmed behavior. Since the behavior was apparently not rectified to the satisfaction of the referee, and the behavior was not severe enough to deserve a DQ, a yellow card was given.
<T11> allows for red cards to be given to the entire alliance, but gives no procedure for yellow cards in elimination rounds. I'm not saying that this ref's interpretation was correct or incorrect, but giving the most likely reasoning. My interpretation up to this point was that a yellow card was given to an individual team on the alliance, but two yellow cards accrued by an alliance results in a DQ for the entire alliance in elims. This may be an incorrect interpretation of the rules. The correct interpretation will no doubt be resolved by the Head Refs this week before the next round of regionals.
At any rate, in general, yellow cards are really no big deal. If you get one you should take it seriously, but since there is no real consequence of a yellow card, save temporary embarrassment, there shouldn't be this much outrage over yellow cards. They're not attached to your "permanent record" and nobody cares about them after the tournament is finished. As defined in T05, a yellow card is an Official Warning, and nothing more.
Orlando Regional Planning Committee & Cohost of
The RoboShow &
RoboVision
Follow The RoboShow on Twitter @
RoboShowLive & check out our website,
www.theroboshow.net
Follow RoboVision on Twitter @
RoboVisionOD & check out our website,
www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
